[petsc-users] Problems with last PETSC-3.2 release on Windows
Fri Sep 16 07:33:18 CDT 2011
Could you tell us - which version of ifort you have? Its strange
that this test works for me [with ifort 10.1] - but not for you.
Satish
On Fri, 16 Sep 2011, Alexander Grayver wrote:
> Satish,
> Thanks a lot! The configure and make stages work well now.
> Regards,
> Alexander
> On 15.09.2011 19:19, Satish Balay wrote:
> > Looks like its related to the the commenting out of the lines [and the
> > failed test before that].
> > After the commented lines - try adding:
> >      self.setCompilers.fortranModuleIncludeFlag = '-I'
> > Satish
> > On Thu, 15 Sep 2011, Alexander Grayver wrote:
> > > Satish,
> > > It is reproducible.
> > > So that is the nasty error, I don't know where to look for solution.
> > > Anyway, I commented these lines in compiler.py as Matt suggested:
> > >      #if not found:
> > >      #  raise RuntimeError('Cannot determine Fortran module include flag')
> > > And configure fails further down, but I suspect that this new error is
> > > also
> > > somehow linked to the relative paths (seen log attached). Can you
> > > confirmthis?
> > > Regards,
> > > Alexander
> > > On 15.09.2011 16:48, Satish Balay wrote:
> > > > I just ran petsc-32 with ifort - and it ran fine. So I'm not sure
> > > > whats hapenning in this case..
> > > > Is this error reproduceable [if configure is rerun with the same
> > > > options?]
> > > > Satish
> > > > Intel(R) Visual Fortran Compiler for applications running on Intel(R)
> > > > 64,
> > > > Version 10.1    Build 20080212 Package ID: w_fc_p_10.1.019
> > > > TEST checkFortranModuleInclude from
> > > > config.compilers(/home/balay/petsc-3.2/config/BuildSystem/config/compilers.py:1155)
> > > > TESTING: checkFortranModuleInclude from
> > > > config.compilers(config/BuildSystem/config/compilers.py:1155)
> > > >     Figures out what flag is used to specify the include path for
> > > > Fortran
> > > > modules
> > > >             Pushing language FC
> > > > sh: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort -c -o
> > > > /tmp/petsc-zRoAJW/config.compilers/conftest.o
> > > > -I/tmp/petsc-zRoAJW/config.compilers
> > > > -I/tmp/petsc-zRoAJW/config.setCompilers
> > > > -MT -Z7 -fpp  /tmp/petsc-zRoAJW/config.compilers/conftest.F
> > > > Executing: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort -c -o
> > > > sh:
> > > > Successful compile:
> > > > Source:
> > > >         module configtest
> > > >         integer testint
> > > >         parameter (testint = 42)
> > > >         end module configtest
> > > >             Pushing language FC
> > > > -I/tmp/petsc-zRoAJW/config.compilers/confdir  -MT -Z7 -fpp
> > > > sh:
> > > > Successful compile:
> > > > Source:
> > > >         program main
> > > >         use configtest
> > > >         write(*,*) testint
> > > >         end
> > > >                     Pushing language FC
> > > >                     Popping language FC
> > > > sh: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort  -o
> > > > /tmp/petsc-zRoAJW/config.compilers/conftest.exe
> > > > /tmp/petsc-zRoAJW/config.compilers/configtest.o
> > > > Executing: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort  -o
> > > > sh: LINK : C:\cygwin\tmp\PETSC-~3\CONFIG~1.COM\conftest.exe not found or
> > > > not
> > > > built by the last incremental link; performing full link^M
> > > >           compilers: Fortran module include flag -I found
> > > >             Popping language FC
> > > > On Thu, 15 Sep 2011, Matthew Knepley wrote:
> > > > > On Thu, Sep 15, 2011 at 8:43 AM, Alexander Grayver
> > > > > <agrayver at gfz-potsdam.de>wrote:
> > > > > > Thanks Matt,
> > > > > > I will that, but I use PETSC from Fortran so I need Fortran
> > > > > > functionality.
> > > > > Sure. Do you use the F90 modules? If so, send us the build problem. If
> > > > > there
> > > > > is not build problem,
> > > > > then ifort supports only relative paths for module includes, which is
> > > > > crazy
> > > > > and will break sometimes.
> > > > >     Thanks,
> > > > >        Matt
> > > > > > Regards,
> > > > > > Alexander
> > > > > > On 15.09.2011 15:43, Matthew Knepley wrote:
> > > > > > On Thu, Sep 15, 2011 at 8:01 AM, Alexander Grayver<
> > > > > > agrayver at gfz-potsdam.de>   wrote:
> > > > > > >    Matthew,
> > > > > > > I found this check in configure.log I obtained for petsc-3.1-p7:
> > > > > > > config.compilers(/cygdrive/d/Dev/petsc-3.1-p7/config/BuildSystem/config/compilers.py:1084)
> > > > > > > config.compilers(config/BuildSystem/config/compilers.py:1084)
> > > > > > > Fortran
> > > > > > > modules
> > > > > > >           Pushing language FC
> > > > > > > sh: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -c -o
> > > > > > > conftest.o  -MT -Z7 -fpp  conftest.F
> > > > > > > Executing: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort
> > > > > > > -c
> > > > > > > -o
> > > > > > > sh:
> > > > > > >           Pushing language FC
> > > > > > > conftest.o -Iconfdir  -MT -Z7 -fpp  conftest.F
> > > > > > > -c
> > > > > > > -o
> > > > > > > sh:
> > > > > > >                   Pushing language FC
> > > > > > >                   Popping language FC
> > > > > > > sh: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort  -o
> > > > > > > conftest.exe   -Iconfdir  -MT -Z7 -fpp  conftest.o configtest.o
> > > > > > > -o
> > > > > > > sh: LINK : D:\Dev\PETSC-~2.1-P\conftest.exe not found or not built
> > > > > > > by
> > > > > > > the
> > > > > > >           Popping language FC
> > > > > > > The compiler I used is the same I use for petsc-3.2-p1.
> > > > > > > The difference is in the paths where you try to build this tests.
> > > > > > > As
> > > > > > > far
> > > > > > > as I understand for petsc-3.1-p7 you used local directory and for
> > > > > > > petsc-3.2-p1 temp directory is used.
> > > > > > > Could it be the reason?
> > > > > >    That would be broken behavior from ifort, but I guess it is
> > > > > > possible.
> > > > > > I
> > > > > > will talk with Satish about how
> > > > > > this should really be fixed. For right now, go to
> > > > > >    to the checkFortranModuleInclude() function and comment out the
> > > > > > last
> > > > > > two
> > > > > > lines, which are killing the configure.
> > > > > > Your build will break on the Fortran modules (I assume), but
> > > > > > everything
> > > > > > else should work.
> > > > > >      Thanks,
> > > > > >          Matt
> > > > > > >    Regards,
> > > > > > >    Alexander
> > > > > > > On 15.09.2011 14:54, Matthew Knepley wrote:
> > > > > > > On Thu, Sep 15, 2011 at 2:49 AM, Alexander Grayver<
> > > > > > > > Hello,
> > > > > > > > I hope you are having nice day!
> > > > > > > > I have been using petsc-3.1-p7 under windows for 6 months and
> > > > > > > > now
> > > > > > > > decided
> > > > > > > > to get new version. I used my old configure line which was
> > > > > > > > successful for
> > > > > > > > petsc-3.1:
> > > > > > > > ./config/configure.py --PETSC_DIR=/cygdrive/d/dev/petsc-3.2-p1
> > > > > > > > --with-petsc-arch=cygwin-cxx-debug-fortran
> > > > > > > > --with-fortran-interfaces=1
> > > > > > > > --with-cc='win32fe cl' --with-fc='win32fe ifort'
> > > > > > > > --with-cxx='win32fe cl'
> > > > > > > > --with-windows-graphics=0 --download-f-blas-lapack=1
> > > > > > > > --with-precision=double
> > > > > > > > --with-scalar-type=complex --with-clanguage=cxx
> > > > > > > > --with-mpi-include="/cygdrive/d/Dev/HPC_2008_SDK/Include"
> > > > > > > > --with-mpi-lib=["/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpi.lib","/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpifec.lib"]
> > > > > > > > --useThreads=0
> > > > > > > > But unfortunately it doesn't work properly anymore, even though
> > > > > > > > my
> > > > > > > > development environment has not been changed. The error is:
> > > > > > > >           UNABLE to CONFIGURE with GIVEN OPTIONS    (see
> > > > > > > > configure.log for
> > > > > > > > details):
> > > > > > > > Please find configure.log attached.
> > > > > > >    The problem here is that your Fortran compiler reports that is
> > > > > > > supports
> > > > > > > F90, but cannot
> > > > > > > locate modules using an include path. This will make parts of the
> > > > > > > PETSc
> > > > > > > build fail. Do you
> > > > > > > know what flag it uses? I try -I, -p, and -M.
> > > > > > >      Thanks,
> > > > > > >         Matt
> > > > > > > > Regards,
> > > > > > > >    Alexander
> > > > > > > What most experimenters take for granted before they begin their
> > > > > > > experiments is infinitely more interesting than any results to
> > > > > > > which
> > > > > > > their
> > > > > > > experiments lead.
> > > > > > > -- Norbert Wiener
> > > > > > experiments is infinitely more interesting than any results to which
> > > > > > their
> > > > > > experiments lead.
> > > > > > -- Norbert Wiener
