[petsc-users] Problems with last PETSC-3.2 release on Windows
Alexander Grayver agrayver at gfz-potsdam.de
Fri Sep 16 05:33:58 CDT 2011
Satish,
Thanks a lot! The configure and make stages work well now.
Alexander
On 15.09.2011 19:19, Satish Balay wrote:
> Looks like its related to the the commenting out of the lines [and the
> failed test before that].
> After the commented lines - try adding:
>      self.setCompilers.fortranModuleIncludeFlag = '-I'
> Satish
> On Thu, 15 Sep 2011, Alexander Grayver wrote:
>> Satish,
>> It is reproducible.
>> So that is the nasty error, I don't know where to look for solution.
>> Anyway, I commented these lines in compiler.py as Matt suggested:
>>      #if not found:
>>      #  raise RuntimeError('Cannot determine Fortran module include flag')
>> And configure fails further down, but I suspect that this new error is also
>> somehow linked to the relative paths (seen log attached). Can you confirmthis?
>> Regards,
>> Alexander
>> On 15.09.2011 16:48, Satish Balay wrote:
>>> I just ran petsc-32 with ifort - and it ran fine. So I'm not sure
>>> whats hapenning in this case..
>>> Is this error reproduceable [if configure is rerun with the same options?]
>>> Satish
>>> Intel(R) Visual Fortran Compiler for applications running on Intel(R) 64,
>>> Version 10.1    Build 20080212 Package ID: w_fc_p_10.1.019
>>> TEST checkFortranModuleInclude from
>>> config.compilers(/home/balay/petsc-3.2/config/BuildSystem/config/compilers.py:1155)
>>> TESTING: checkFortranModuleInclude from
>>> config.compilers(config/BuildSystem/config/compilers.py:1155)
>>>     Figures out what flag is used to specify the include path for Fortran
>>> modules
>>>             Pushing language FC
>>> sh: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort -c -o
>>> /tmp/petsc-zRoAJW/config.compilers/conftest.o
>>> -I/tmp/petsc-zRoAJW/config.compilers -I/tmp/petsc-zRoAJW/config.setCompilers
>>> -MT -Z7 -fpp  /tmp/petsc-zRoAJW/config.compilers/conftest.F
>>> Executing: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort -c -o
>>> sh:
>>> Successful compile:
>>> Source:
>>>         module configtest
>>>         integer testint
>>>         parameter (testint = 42)
>>>         end module configtest
>>>             Pushing language FC
>>> -I/tmp/petsc-zRoAJW/config.compilers/confdir  -MT -Z7 -fpp
>>> sh:
>>> Successful compile:
>>> Source:
>>>         program main
>>>         use configtest
>>>         write(*,*) testint
>>>         end
>>>                     Pushing language FC
>>>                     Popping language FC
>>> sh: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort  -o
>>> /tmp/petsc-zRoAJW/config.compilers/conftest.exe
>>> /tmp/petsc-zRoAJW/config.compilers/configtest.o
>>> Executing: /home/balay/petsc-3.2/bin/win32fe/win32fe ifort  -o
>>> sh: LINK : C:\cygwin\tmp\PETSC-~3\CONFIG~1.COM\conftest.exe not found or not
>>> built by the last incremental link; performing full link^M
>>>           compilers: Fortran module include flag -I found
>>>             Popping language FC
>>> On Thu, 15 Sep 2011, Matthew Knepley wrote:
>>>> On Thu, Sep 15, 2011 at 8:43 AM, Alexander Grayver
>>>> <agrayver at gfz-potsdam.de>wrote:
>>>>> Thanks Matt,
>>>>> I will that, but I use PETSC from Fortran so I need Fortran
>>>>> functionality.
>>>> Sure. Do you use the F90 modules? If so, send us the build problem. If
>>>> there
>>>> is not build problem,
>>>> then ifort supports only relative paths for module includes, which is
>>>> crazy
>>>> and will break sometimes.
>>>>     Thanks,
>>>>        Matt
>>>>> Regards,
>>>>> Alexander
>>>>> On 15.09.2011 15:43, Matthew Knepley wrote:
>>>>> On Thu, Sep 15, 2011 at 8:01 AM, Alexander Grayver<
>>>>> agrayver at gfz-potsdam.de>   wrote:
>>>>>>    Matthew,
>>>>>> I found this check in configure.log I obtained for petsc-3.1-p7:
>>>>>> config.compilers(/cygdrive/d/Dev/petsc-3.1-p7/config/BuildSystem/config/compilers.py:1084)
>>>>>> config.compilers(config/BuildSystem/config/compilers.py:1084)
>>>>>> Fortran
>>>>>> modules
>>>>>>           Pushing language FC
>>>>>> sh: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -c -o
>>>>>> conftest.o  -MT -Z7 -fpp  conftest.F
>>>>>> Executing: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -c
>>>>>> -o
>>>>>> sh:
>>>>>>           Pushing language FC
>>>>>> conftest.o -Iconfdir  -MT -Z7 -fpp  conftest.F
>>>>>> -o
>>>>>> sh:
>>>>>>                   Pushing language FC
>>>>>>                   Popping language FC
>>>>>> sh: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort  -o
>>>>>> conftest.exe   -Iconfdir  -MT -Z7 -fpp  conftest.o configtest.o
>>>>>> Executing: /cygdrive/d/Dev/petsc-3.1-p7/bin/win32fe/win32fe ifort  -o
>>>>>> sh: LINK : D:\Dev\PETSC-~2.1-P\conftest.exe not found or not built by
>>>>>> the
>>>>>>           Popping language FC
>>>>>> The compiler I used is the same I use for petsc-3.2-p1.
>>>>>> The difference is in the paths where you try to build this tests. As
>>>>>> far
>>>>>> as I understand for petsc-3.1-p7 you used local directory and for
>>>>>> petsc-3.2-p1 temp directory is used.
>>>>>> Could it be the reason?
>>>>>    That would be broken behavior from ifort, but I guess it is possible.
>>>>> I
>>>>> will talk with Satish about how
>>>>> this should really be fixed. For right now, go to
>>>>>    to the checkFortranModuleInclude() function and comment out the last
>>>>> two
>>>>> lines, which are killing the configure.
>>>>> Your build will break on the Fortran modules (I assume), but everything
>>>>> else should work.
>>>>>      Thanks,
>>>>>          Matt
>>>>>>    Regards,
>>>>>>    Alexander
>>>>>> On 15.09.2011 14:54, Matthew Knepley wrote:
>>>>>> On Thu, Sep 15, 2011 at 2:49 AM, Alexander Grayver<
>>>>>>> Hello,
>>>>>>> I hope you are having nice day!
>>>>>>> I have been using petsc-3.1-p7 under windows for 6 months and now
>>>>>>> decided
>>>>>>> to get new version. I used my old configure line which was
>>>>>>> successful for
>>>>>>> petsc-3.1:
>>>>>>> ./config/configure.py --PETSC_DIR=/cygdrive/d/dev/petsc-3.2-p1
>>>>>>> --with-petsc-arch=cygwin-cxx-debug-fortran
>>>>>>> --with-fortran-interfaces=1
>>>>>>> --with-cc='win32fe cl' --with-fc='win32fe ifort'
>>>>>>> --with-cxx='win32fe cl'
>>>>>>> --with-windows-graphics=0 --download-f-blas-lapack=1
>>>>>>> --with-precision=double
>>>>>>> --with-scalar-type=complex --with-clanguage=cxx
>>>>>>> --with-mpi-include="/cygdrive/d/Dev/HPC_2008_SDK/Include"
>>>>>>> --with-mpi-lib=["/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpi.lib","/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpifec.lib"]
>>>>>>> --useThreads=0
>>>>>>> But unfortunately it doesn't work properly anymore, even though my
>>>>>>> development environment has not been changed. The error is:
>>>>>>>           UNABLE to CONFIGURE with GIVEN OPTIONS    (see
>>>>>>> configure.log for
>>>>>>> details):
>>>>>>> Please find configure.log attached.
>>>>>>    The problem here is that your Fortran compiler reports that is
>>>>>> supports
>>>>>> F90, but cannot
>>>>>> locate modules using an include path. This will make parts of the
>>>>>> PETSc
>>>>>> build fail. Do you
>>>>>> know what flag it uses? I try -I, -p, and -M.
>>>>>>      Thanks,
>>>>>>         Matt
>>>>>>> Regards,
>>>>>>>    Alexander
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which
>>>>>> their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
