[petsc-users] Neumann BC for interface elliptic problem
Wed Sep 14 07:28:00 CDT 2011
On Sep 14, 2011, at 5:20 AM, Marco Cisternino wrote:
> "Everything" means everything: the solver converges with rtol=10^(-12) to the right solution.
> For tests with problems the solver converges but to a deformed solution.
   If the KSP solver converges (but to a deformed solution) this means the linear system must not be defined to be the same as before, for example the matrix is wrong.
    Barry
> I'm trying some other test, I would like to tell you exactly which is the difference between working and not working cases.
> thanks.
> Marco
> Marco Cisternino
> PhD Student
> Politecnico di Torino
> Email:marco.cisternino at polito.it
