[petsc-users] Building PETSc with cmake
Tue Sep 13 09:48:28 CDT 2011
It should work in petsc-32. Can you send configure.log to petsc-maint?
Satish
On Tue, 13 Sep 2011, John Fettig wrote:
> On Tue, Sep 13, 2011 at 10:09 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> Is there any way to tell configure which python to use?  I have python
> >> 2.6 installed, it's just not what runs when you type `python`.  I
> >> don't think I can change the default python in CentOS 5 without
> >> breaking a lot of other things.
> > /path/to/python2.6 configure  [configure_options]
> This gets configure to try cmake, but it still doesn't use it.  It
> doesn't set "PETSC_BUILD_USING_CMAKE" to "1" as I see the nightly
> builds doing, and again doesn't offer for me to use cmake at the end
> of configure.  Is this only available in petsc-dev?
> Thanks,
> John
> Invoking: ['/usr/local/bin/cmake',
> '/home/jfe/local/centos/petsc-3.2-p0',
> '-DCMAKE_C_COMPILER:FILEPATH=icc', '-DCMAKE_C_FLAGS:STRING= -fPIC
> -wd1572 -Qoption,cpp,--extended_float_type -g -debug
> inline_debug_info', '-DCMAKE_Fortran_COMPILER:FILEPATH=ifort',
> '-DCMAKE_Fortran_FLAGS:STRING= -fPIC -g -debug inline_debug_info']
> sh: ['/usr/local/bin/cmake', '/home/jfe/local/centos/petsc-3.2-p0',
> Executing: ['/usr/local/bin/cmake',
> sh: -- The C compiler identification is Intel
> -- Check for working C compiler: /opt/intel/Compiler/11.1/072/bin/intel64/icc
> /opt/intel/Compiler/11.1/072/bin/intel64/icc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- The Fortran compiler identification is Intel
> -- Check for working Fortran compiler:
> /opt/intel/Compiler/11.1/072/bin/intel64/ifort
> /opt/intel/Compiler/11.1/072/bin/intel64/ifort  -- works
> -- Detecting Fortran compiler ABI info
> -- Detecting Fortran compiler ABI info - done
> -- Checking whether /opt/intel/Compiler/11.1/072/bin/intel64/ifort
> supports Fortran 90
> supports Fortran 90 -- yes
> -- Configuring done
> -- Generating done
> -- Build files have been written to:
> /home/jfe/local/centos/petsc-3.2-p0/intel-debug
