[petsc-users] PETSc 3.2 gmres error
Tabrez Ali
stali at geology.wisc.edu
Sat Sep 10 12:13:47 CDT 2011
Thanks! Everything works fine now.
Tabrez
On 09/10/2011 10:50 AM, Satish Balay wrote:
> You can disable these checks if you build PETSc with --with-debugging=0
> The slight difference in numerical values computed by the 2 different
> compiler/glibc versions [or slight difference in fpu hardware in the 2
> machines] could be the reason for this test to fail.
> Satish
> On Sat, 10 Sep 2011, Tabrez Ali wrote:
>> Jed
>> Thanks for your reply. Yes I should have tested with a PETSc example. I do get
>> the same error (see below) with ex2 in src/ksp/ksp/examples/tutorials with
>> GMRES. Again CG works fine though.
>> So I guess my code is fine and something is wrong with my setup.
>> Satish
>> Yes everything runs fine as 2 jobs on a single machine and that is how I
>> usually test. I was just experimenting here.
>> Tabrez
>> stali at i5:~/petsc-dev/src/ksp/ksp/examples/tutorials$ mpiexec -f hosts -n 2
>> ./ex2 -ksp_type cg -ksp_monitor
>> 0 KSP Residual norm 3.562148313266e+00
>> 1 KSP Residual norm 1.215355568718e+00
>> 2 KSP Residual norm 5.908378943191e-01
>> 3 KSP Residual norm 2.388447476613e-01
>> 4 KSP Residual norm 5.291449320146e-02
>> 5 KSP Residual norm 1.227766600895e-02
>> 6 KSP Residual norm 2.190918491891e-03
>> 7 KSP Residual norm 3.758527933277e-04
>> Norm of error 0.000432115 iterations 7
>> ./ex2 -ksp_type gmres -ksp_monitor
>> 1 KSP Residual norm 1.215348368658e+00
>> 2 KSP Residual norm 5.599263969157e-01
>> 3 KSP Residual norm 2.185276631601e-01
>> 4 KSP Residual norm 5.060212909332e-02
>> 5 KSP Residual norm 1.172638597604e-02
>> 6 KSP Residual norm 2.158149739691e-03
>> 7 KSP Residual norm 3.696833900173e-04
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Invalid argument!
>> [0]PETSC ERROR: Scalar value must be same on all processes, argument # 3!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Petsc Development HG revision:
>> a8941623c0b6225ff3688949b01271e9ae85a545 HG Date: Fri Sep 09 19:37:41 2011
>> -0500
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: ./ex2 on a arch-linu named i5 by stali Sat Sep 10 10:27:41
>> 2011
>> [0]PETSC ERROR: Libraries linked from /opt/petsc-3.2/lib
>> [0]PETSC ERROR: Configure run at Sat Sep 10 10:02:38 2011
>> [0]PETSC ERROR: Configure options --prefix=/opt/petsc-3.2
>> --with-mpi-dir=/opt/mpich2-gcc --with-parmetis=1 --download-parmetis=1
>> --with-shared-libraries
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: VecMAXPY() line 1190 in src/vec/vec/interface/rvector.c
>> [0]PETSC ERROR: BuildGmresSoln() line 345 in src/ksp/ksp/impls/gmres/gmres.c
>> [0]PETSC ERROR: GMREScycle() line 206 in src/ksp/ksp/impls/gmres/gmres.c
>> [0]PETSC ERROR: KSPSolve_GMRES() line 231 in src/ksp/ksp/impls/gmres/gmres.c
>> [0]PETSC ERROR: KSPSolve() line 423 in src/ksp/ksp/interface/itfunc.c
>> [0]PETSC ERROR: main() line 199 in src/ksp/ksp/examples/tutorials/ex2.c
>> application called MPI_Abort(MPI_COMM_WORLD, 62) - process 0
>> [cli_0]: aborting job:
>> On 09/10/2011 06:38 AM, Jed Brown wrote:
>>> On Sat, Sep 10, 2011 at 13:09, Tabrez Ali<stali at geology.wisc.edu
>>> <mailto:stali at geology.wisc.edu>> wrote:
>>> Hello
>>> I am running an application using PETSc 3.2 RC on a poor mans
>>> cluster at my home (for testing only) which has two nodes running
>>> different versions of Debian (they also have different versions of
>>> gcc/gfortran) but have the same MPICH2 1.4 and PETSc 3.2 installed
>>> on them.
>>> Also they do not share the same file system but I make sure that
>>> input file/executable paths are exactly same on both machines.
>>> After compiling the code separately on the two nodes I launch the
>>> parallel program from node 1 using mpiexec -f hosts -n 2 ....
>>> (hydra process manager).
>>> With PETSc 3.1 the application runs fine, both with CG and GMRES
>>> and correct output is generated on both nodes.
>>> With PETSc 3.2 the application runs fine with CG.
>>> But whenever I use GMRES in 3.2 I get an error (listed below)
>>> during KSPSolve.
>>> Can you reproduce this with any of the examples? For example
>>> cd src/ksp/ksp/examples/tutorials
>>> make ex2
>>> mpiexec -f hosts -n 2 ./ex2 -ksp_type gmres
>>> or, to use your matrix, run (any version that works, including 3.1) with
>>> -ksp_view_binary and then
>>> make ex10
>>> mpiexec -f hosts -n 2 ./ex10 -f binaryoutput -ksp_type gmres
>>> If these work, there might be memory corruption somewhere in your code
>>> causing this.
>>> You can also run with -start_in_debugger and check what is in the "alpha"
>>> array on each process.
