[petsc-users] PETSc 3.2 gmres error
Tabrez Ali stali at geology.wisc.edu
Sat Sep 10 10:12:31 CDT 2011
Jed
Thanks for your reply. Yes I should have tested with a PETSc example. I
do get the same error (see below) with ex2 in
src/ksp/ksp/examples/tutorials with GMRES. Again CG works fine though.
So I guess my code is fine and something is wrong with my setup.
Satish
Yes everything runs fine as 2 jobs on a single machine and that is how I
usually test. I was just experimenting here.
Tabrez
stali at i5:~/petsc-dev/src/ksp/ksp/examples/tutorials$ mpiexec -f hosts -n
2 ./ex2 -ksp_type cg -ksp_monitor
   0 KSP Residual norm 3.562148313266e+00
   1 KSP Residual norm 1.215355568718e+00
   2 KSP Residual norm 5.908378943191e-01
   3 KSP Residual norm 2.388447476613e-01
   4 KSP Residual norm 5.291449320146e-02
   5 KSP Residual norm 1.227766600895e-02
   6 KSP Residual norm 2.190918491891e-03
   7 KSP Residual norm 3.758527933277e-04
Norm of error 0.000432115 iterations 7
2 ./ex2 -ksp_type gmres -ksp_monitor
   1 KSP Residual norm 1.215348368658e+00
   2 KSP Residual norm 5.599263969157e-01
   3 KSP Residual norm 2.185276631601e-01
   4 KSP Residual norm 5.060212909332e-02
   5 KSP Residual norm 1.172638597604e-02
   6 KSP Residual norm 2.158149739691e-03
   7 KSP Residual norm 3.696833900173e-04
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Invalid argument!
[0]PETSC ERROR: Scalar value must be same on all processes, argument # 3!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
a8941623c0b6225ff3688949b01271e9ae85a545  HG Date: Fri Sep 09 19:37:41
2011 -0500
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./ex2 on a arch-linu named i5 by stali Sat Sep 10
10:27:41 2011
[0]PETSC ERROR: Libraries linked from /opt/petsc-3.2/lib
[0]PETSC ERROR: Configure run at Sat Sep 10 10:02:38 2011
[0]PETSC ERROR: Configure options --prefix=/opt/petsc-3.2
--with-mpi-dir=/opt/mpich2-gcc --with-parmetis=1 --download-parmetis=1
--with-shared-libraries
[0]PETSC ERROR:
[0]PETSC ERROR: VecMAXPY() line 1190 in src/vec/vec/interface/rvector.c
[0]PETSC ERROR: BuildGmresSoln() line 345 in src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: GMREScycle() line 206 in src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: KSPSolve_GMRES() line 231 in src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: KSPSolve() line 423 in src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: main() line 199 in src/ksp/ksp/examples/tutorials/ex2.c
application called MPI_Abort(MPI_COMM_WORLD, 62) - process 0
[cli_0]: aborting job:
On 09/10/2011 06:38 AM, Jed Brown wrote:
> On Sat, Sep 10, 2011 at 13:09, Tabrez Ali <stali at geology.wisc.edu
> <mailto:stali at geology.wisc.edu>> wrote:
>     Hello
>     I am running an application using PETSc 3.2 RC on a poor mans
>     cluster at my home (for testing only) which has two nodes running
>     different versions of Debian (they also have different versions of
>     gcc/gfortran) but have the same MPICH2 1.4 and PETSc 3.2 installed
>     on them.
>     Also they do not share the same file system but I make sure that
>     input file/executable paths are exactly same on both machines.
>     After compiling the code separately on the two nodes I launch the
>     parallel program from node 1 using mpiexec -f hosts -n 2 ....
>     (hydra process manager).
>     With PETSc 3.1 the application runs fine, both with CG and GMRES
>     and correct output is generated on both nodes.
>     With PETSc 3.2 the application runs fine with CG.
>     But whenever I use GMRES in 3.2 I get an error (listed below)
>     during KSPSolve.
> Can you reproduce this with any of the examples? For example
> cd src/ksp/ksp/examples/tutorials
> make ex2
> mpiexec -f hosts -n 2 ./ex2 -ksp_type gmres
> or, to use your matrix, run (any version that works, including 3.1)
> with -ksp_view_binary and then
> make ex10
> mpiexec -f hosts -n 2 ./ex10 -f binaryoutput -ksp_type gmres
> If these work, there might be memory corruption somewhere in your code
> causing this.
> You can also run with -start_in_debugger and check what is in the
> "alpha" array on each process.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110910/732fc7cb/attachment-0001.htm>
