[petsc-users] PETSc 3.2 gmres error
    Matthew Knepley
    knepley at gmail.com
    Sat Sep 10 08:29:40 CDT 2011
On Sat, Sep 10, 2011 at 6:38 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sat, Sep 10, 2011 at 13:09, Tabrez Ali <stali at geology.wisc.edu> wrote:
>> Hello
>> I am running an application using PETSc 3.2 RC on a poor mans cluster at
>> my home (for testing only) which has two nodes running different versions of
>> Debian (they also have different versions of gcc/gfortran) but have the same
>> MPICH2 1.4 and PETSc 3.2 installed on them.
>> Also they do not share the same file system but I make sure that input
>> file/executable paths are exactly same on both machines. After compiling the
>> code separately on the two nodes I launch the parallel program from node 1
>> using mpiexec -f hosts -n 2 .... (hydra process manager).
>> With PETSc 3.1 the application runs fine, both with CG and GMRES and
>> correct output is generated on both nodes.
>> With PETSc 3.2 the application runs fine with CG.
>> But whenever I use GMRES in 3.2 I get an error (listed below) during
>> KSPSolve.
> Can you reproduce this with any of the examples? For example
> cd src/ksp/ksp/examples/tutorials
> make ex2
> mpiexec -f hosts -n 2 ./ex2 -ksp_type gmres
> or, to use your matrix, run (any version that works, including 3.1) with
> -ksp_view_binary and then
> make ex10
> mpiexec -f hosts -n 2 ./ex10 -f binaryoutput -ksp_type gmres
> If these work, there might be memory corruption somewhere in your code
> causing this.
> You can also run with -start_in_debugger and check what is in the "alpha"
> array on each process.
This can happen if a NaN is produced as well. You can easily check by
launching the debugger and
printing the value.
   Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110910/f17e3dbc/attachment.htm>
