[petsc-users] PETSc config error
amrit poudel amrit_pou at hotmail.com
Wed Sep 7 19:01:04 CDT 2011
I tried configuring it  with  --with-batch , but I still cannot get past the error (see below)
 ./config/configure.py --prefix=/home/amrit/PETSc --with-scalar-type=complex --with-batch --with-cc=/home/amrit/MPI/bin/mpicc --with-fc=/home/amrit/MPI/bin/mpif77
             Configuring PETSc to compile on your system
TESTING: configureMPIEXEC from config.packages.MPI(config/BuildSystem/config/pac*******************************************************************************
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
Must give a default value for known-mpi-shared since executables cannot be run
Thanks for any help.
To: petsc-users at mcs.anl.gov
Date: Wed, 7 Sep 2011 23:50:46 +0000
Subject: [petsc-users] PETSc config error
I get the following error (down below) when I try to configure PETSc with this command (on a scientific Linux OS) :
 ./config/configure.py --prefix=/home/amrit/PETSc --with-scalar-type=complex --with-cc=/home/amrit/MPI/bin/mpicc --with-fc=/home/amrit/MPI/bin/mpif77
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCo*******************************************************************************
                    UNABLE to EXECUTE BINARIES for config/configure.py
Cannot run executables created with C. If this machine uses a batch system
to submit jobs you will need to configure using/configure.py with the additional option  --with-batch.
 Otherwise there is problem with the compilers. Can you compile and run code with your C/C++ (and maybe Fortran) compilers?
I am sure that fortran and C/C++ compilers are okay on this computer.
Any help will be appreciated.
Thanks.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110908/d17be810/attachment.htm>
