[petsc-users] Write complex matrix/vector from Matlab
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Sep  4 21:14:24 CDT 2011
  Amrit,
    We have just recently made sure that PetscBinaryWrite.m and PetscBinaryRead.m fully support complex numbers; you can access the release candidate for PETSc 3.2 for this support
One can use the following tarball. It will correspond to
petsc-3.2 sources for the next few days. And i've set it up to be
updated every 3 hours [from the sources in mercurial].
http://ftp.mcs.anl.gov/pub/petsc/petsc-dev.tar.gz
or
>   You can find the PETSc 3.2 release candidate via Mecurial at:
>> ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/petsc-3.2                        or    http://petsc.cs.iit.edu/petsc/releases/petsc-3.2
>> ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/BuildSystem-3.2           or    http://petsc.cs.iit.edu/petsc/releases/BuildSystem-3.2
  Should you have problems reading the complex matrices/vectors saved from MATLAB please send all information to petsc-maint at mcs.anl.gov
  We do not support the Matrix Market sparse format because it is not scalable for large matrices (i.e. it is too slow) ; reading ASCII files in parallel is not viable.
  Barry
On Sep 4, 2011, at 9:05 PM, amrit poudel wrote:
> Hello everyone,
> Does anyone here know how one can write a complex or real, matrix or vector (matrix could be sparse or full) in MATLAB  to a binary file  such that it can be read correctly by PETSc?
> I tried using  PetscBinaryWrite.m that came with PETSc ( /bin/matlab) to write a simple real (or complex), full (or sparse) matrix in binary file named 'matrix.dat' and tried reading it in PETSc, but it absolutely does not work :(
> I did PetscBinaryWrite('matrix.dat', C) to write a matrix C in an empty file named 'matrix.dat' in MATLAB. Then I tried reading 'matrix.dat' file in PETSc using the following command :
> PetscViewer        binviewer ;
> Mat                    C ;
> char            fileC[PETSC_MAX_PATH_LEN] ;
> ierr = PetscOptionsGetString(PETSC_NULL, "-fC", fileC, PETSC_MAX_PATH_LEN-1, PETSC_NULL) ; CHKERRQ(ierr) ;
> ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD, fileC, FILE_MODE_READ, &binviewer) ; CHKERRQ(ierr) ;
> ierr = MatLoad(binviewer, MATMPIAIJ, &C) ; CHKERRQ(ierr) ;
> I must add that I compiled PETSc with complex numbers.
> I plan on assembling my matrix (very large square sparse matrix, size greater than 1e+8) in MATLAB, which does not take too long to assemble in MATLAB at all. Then I will write the matrix to a binary file and read that in PETSc and solve a very large linear system of equations in parallel in PETSc using MPI. Hence, I really need to be able to write the matrix in MATLAB to a binary file  such that PETSc can correctly read the matrix.
> I am really surprised to find out that PETSc cannot read/write a matrix or vector, full or sparse, real or complex in MATRIX MARKET FORMAT. I have gone though the manual, googled around quite a bit, but I just have not found anything useful.
>  I will truly appreciate any help or a pointer in this regard.
> Thank you.
> Amrit
