[petsc-users] src/ksp/ksp/examples/tutorials/ex22.c
Alexey Ryazanov amryazanov at gmail.com
Sun Sep 4 11:55:24 CDT 2011
Thank You!
2011/9/4 Matthew Knepley <knepley at gmail.com>
> On Sun, Sep 4, 2011 at 10:08 AM, Алексей Рязанов <ram at ibrae.ac.ru> wrote:
>> Hello!
>> Help me please to solve my tiny problem with dmmg.
>> In the example src/ksp/ksp/examples/tutorials/ex22.c, which is discussed
>> on the 111th page of users manual, we use function
>> (line 36):
>> DACreate3d(PETSC_COMM_WORLD,DA_NONPERIODIC,DA_STENCIL_STAR,-3,-3,-3,PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE,1,1,0,0,0,&da);
>> to "*create the DA that stores information about the coarsest grid you
>> wish to use*".
>> We can see that negative dimension values (-M, -N, -P) are used  "*to
>> indicate that it may be set to a different value from the command line with
>> -da_grid_x <M> -da_grid_y <N> -da_grid_z <P>". *
>> The question is: when I use -da_grid_ M,N,P options as the size of the
>> coarsest matrix, what's the size of the finest (most accurate, original
>> problem) matrix?
>> I've tried to clear this up, using VecVew on the residual vector and
>> figured out, that when i'm using M,N,P as input parameters (so define the
>> coarsest grid as field of M*N*P dots), I get the residual vector of size
>> (4*M-3)*(4*N-3)*(4*P-3).
>> Is my result correct?  If yes, could you please explain why it happens in
>> this way.
> When refinement happens, it adds a vertex between any two vertices,
> starting with the mesh you provide.
>    Matt
>> Sorry if my question is incorrect. I could mix up everything at all.
>> Thanks in advance!
>> Best regards,
>> Alexey Ryazanov
>> ______________________________________
>> Nuclear Safety Institute of Russian Academy of Sciences
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110904/83350af6/attachment.htm>
