[petsc-users] src/ksp/ksp/examples/tutorials/ex22.c
Sun Sep 4 10:50:39 CDT 2011
On Sun, Sep 4, 2011 at 10:08 AM, Алексей Рязанов <ram at ibrae.ac.ru> wrote:
> Hello!
> Help me please to solve my tiny problem with dmmg.
> In the example src/ksp/ksp/examples/tutorials/ex22.c, which is discussed on
> the 111th page of users manual, we use function
> (line 36):
> DACreate3d(PETSC_COMM_WORLD,DA_NONPERIODIC,DA_STENCIL_STAR,-3,-3,-3,PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE,1,1,0,0,0,&da);
> to "*create the DA that stores information about the coarsest grid you
> wish to use*".
> We can see that negative dimension values (-M, -N, -P) are used  "*to
> indicate that it may be set to a different value from the command line with
> -da_grid_x <M> -da_grid_y <N> -da_grid_z <P>". *
> The question is: when I use -da_grid_ M,N,P options as the size of the
> coarsest matrix, what's the size of the finest (most accurate, original
> problem) matrix?
> I've tried to clear this up, using VecVew on the residual vector and
> figured out, that when i'm using M,N,P as input parameters (so define the
> coarsest grid as field of M*N*P dots), I get the residual vector of size
> (4*M-3)*(4*N-3)*(4*P-3).
> Is my result correct?  If yes, could you please explain why it happens in
> this way.
When refinement happens, it adds a vertex between any two vertices, starting
with the mesh you provide.
   Matt
> Sorry if my question is incorrect. I could mix up everything at all.
> Thanks in advance!
> Best regards,
> Alexey Ryazanov
> ______________________________________
> Nuclear Safety Institute of Russian Academy of Sciences
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110904/5f0bace8/attachment-0001.htm>
