[petsc-users] How to change PC content during Iterations
behzad baghapour
behzad.baghapour at gmail.com
Mon Oct 31 06:14:02 CDT 2011
This means to PCDestroy() and then PCCreate again at that iteration?
On Mon, Oct 31, 2011 at 2:32 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Oct 31, 2011 at 10:58 AM, behzad baghapour <
> behzad.baghapour at gmail.com> wrote:
>> I did it but received this Error when I want to change the level of fill
>> for PCILU:
> Right, you would have to recreate the preconditioner. The SetType() would
> not work since
> you did not actually change the type.
> Matt
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Object is in wrong state!
>> [0]PETSC ERROR: Cannot change levels after use!
>> [0]PETSC ERROR:
>> On Mon, Oct 31, 2011 at 2:19 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Mon, Oct 31, 2011 at 8:55 AM, behzad baghapour <
>>>> Dear all,
>>>> I'm using KSP iteration (for now) to solve my nonlinear problem and
>>>> handling Newton Iterations manually. Here I want to change the PC method
>>>> from some specified KSP iteration. How should I do it correctly in Petsc?
>>> Call PCSetType() and then KSPSetOperators() again in your loop
>>> Matt
>>>> Thanks, B.B.
>>>> Behzad Baghapour
>>>> Ph.D. Candidate, Mechecanical Engineering
>>>> University of Tehran, Tehran, Iran
>>>> https://sites.google.com/site/behzadbaghapour
>>>> Fax: 0098-21-88020741
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> Behzad Baghapour
> experiments lead.
> -- Norbert Wiener
Behzad Baghapour
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111031/c4fb0545/attachment.htm>
