[petsc-users] How to change PC content during Iterations
Mon Oct 31 06:02:56 CDT 2011
On Mon, Oct 31, 2011 at 10:58 AM, behzad baghapour <
behzad.baghapour at gmail.com> wrote:
> I did it but received this Error when I want to change the level of fill
> for PCILU:
Right, you would have to recreate the preconditioner. The SetType() would
not work since
you did not actually change the type.
   Matt
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Object is in wrong state!
> [0]PETSC ERROR: Cannot change levels after use!
> [0]PETSC ERROR:
> On Mon, Oct 31, 2011 at 2:19 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Mon, Oct 31, 2011 at 8:55 AM, behzad baghapour <
>>> Dear all,
>>> I'm using KSP iteration (for now) to solve my nonlinear problem and
>>> handling Newton Iterations manually. Here I want to change the PC method
>>> from some specified KSP iteration. How should I do it correctly in Petsc?
>> Call PCSetType() and then KSPSetOperators() again in your loop
>>    Matt
>>> Thanks, B.B.
>>> Behzad Baghapour
>>> Ph.D. Candidate, Mechecanical Engineering
>>> University of Tehran, Tehran, Iran
>>> https://sites.google.com/site/behzadbaghapour
>>> Fax: 0098-21-88020741
>> experiments lead.
>> -- Norbert Wiener
> Behzad Baghapour
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111031/df135db2/attachment-0001.htm>
