[petsc-users] Petsc-3.2 with superlu_dist building error
Ping Rong ping.rong at tu-harburg.de
Thu Oct 27 16:09:04 CDT 2011
Thank you guys! I think I understood the problem, have seen the
changelog of superlu_dist3.0, but I checked the configuration report,
saw that superlu_dist-2.5 is used, so I didn't think of that as a
problem. anyway, I will give another try, when I get to the office tmw.
On 27.10.2011 21:20, Jed Brown wrote:
> On Thu, Oct 27, 2011 at 13:11, Xiaoye S. Li <xsli at lbl.gov
> <mailto:xsli at lbl.gov>> wrote:
>     The error is related to the new SuperLU_DIST (v3.0), not serial
>     SuperLU.
>     In PETSc / SuperLU_DIST wrapper:  superlu_dist.c, line 634,  DOUBLE
>     should be replaced by SLU_DOUBLE.
> Sherry, this is in the released version of PETSc which uses
> SuperLU_DIST-2.5 and SuperLU-4.2. While petsc-dev has been updated for
> SuperLU_DIST-3.0, your API change in the SuperLU-4.2 tarball breaks
> petsc-3.2 (and any other library that was released with support for
> SuperLU-4.2). As we discussed last week, please revert the SuperLU-4.2
> tarball to have the same API as it had when it was released and make
> the API change in a new tarball (e.g. 4.3).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111027/a1505d6c/attachment.htm>
