[petsc-users] Petsc-3.2 with superlu_dist building error
Thu Oct 27 14:20:56 CDT 2011
On Thu, Oct 27, 2011 at 13:11, Xiaoye S. Li <xsli at lbl.gov> wrote:
> The error is related to the new SuperLU_DIST (v3.0), not serial SuperLU.
> In PETSc / SuperLU_DIST wrapper:  superlu_dist.c, line 634,  DOUBLE
> should be replaced by SLU_DOUBLE.
Sherry, this is in the released version of PETSc which uses SuperLU_DIST-2.5
and SuperLU-4.2. While petsc-dev has been updated for SuperLU_DIST-3.0, your
API change in the SuperLU-4.2 tarball breaks petsc-3.2 (and any other
library that was released with support for SuperLU-4.2). As we discussed
last week, please revert the SuperLU-4.2 tarball to have the same API as it
had when it was released and make the API change in a new tarball (e.g.
4.3).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111027/bc4d3f5d/attachment.htm>
