[petsc-users] Binary I/O
Wed Oct 12 21:05:15 CDT 2011
On Oct 12, 2011, at 7:40 PM, Mohamad M. Nasr-Azadani wrote:
> Hi again,
> On the similar topic, how hard would it be to write a function similar to the PETSc's VecView() associated with Binary writer to do exactly the same thing, i.e. write a parallel vector into one single file but when writing all the processors are performing the task simultaneously?
   Impossible. In the end in a standard filesystem the physical hard disk is connected to a single CPU and everything that gets written to that hard disk has to go through that one CPU; there is no way physically for a bunch of CPUs to write together onto a single physical disk.
   Now in high end parallel file systems each file may be spread over several hard disks (this is sometimes called stripping) (say 8). In that case there is some parallelism in writing the data since eight different parts of the vector can be sent through 8 different CPUs to 8 disks. But note that in general the number of these disks that file is spread over is small, like 8, it is never 10,000. When you have a parallel file system and use the option -viewer_binary_mpiio then the PETSc VecView() uses MPI IO to do the writing and you do get this level of parallelism so you may get slightly better performance than not using MPI IO.
   If you are seeing long wait times in VecView() with the binary file it is likely it is because the file server is connected via some pretty slow network to the actual compute nodes on parallel machine and nothing to do with the details of VecView(). You need to make sure you are writing directly to a disk that is on a compute node of the parallel machine, not over some network using NFS (Network File System), this can make a huge difference in time.
   Barry
> Best,
> Mohamad
> On Wed, Oct 12, 2011 at 4:17 PM, Mohamad M. Nasr-Azadani <mmnasr at gmail.com> wrote:
> Thanks Barry. That makes perfect sense.
> Best,
> Mohamad
> On Wed, Oct 12, 2011 at 3:50 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Oct 12, 2011, at 5:42 PM, Mohamad M. Nasr-Azadani wrote:
> > Hi everyone,
> > I think I know the answer to my question, but I was double checking.
> > When using
> > PetscViewerBinaryOpen();
> > It is mentioned that
> > "For writing files it only opens the file on processor 0 in the communicator."
> > Does that mean when writing a parallel vector to file using VecView(), all the data from other processors is first sent to processor zero and then dumped into the file?
>   No all the data is not sent to process zero before writing. That is process 0 does not need enough memory to store all the data before writing.
>    Instead the processes take turns sending data to process 0 who immediately writes it out out to disk.
> > If so, that would be a very slow processor for big datasets and large number of processor?
>   For less than a few thousand processes this is completely fine and nothing else would be much faster
> > Any suggestions to speed that process up?
>   We have the various MPI IO options that uses MPI IO to have several processes writing to disks at the same time that is useful for very large numbers of processes.
>   Barry
> > Best,
> > Mohamad
