[petsc-users] Memory problem
Matthew Knepley
knepley at gmail.com
Thu Oct 6 14:55:46 CDT 2011
On Thu, Oct 6, 2011 at 10:27 AM, Rongliang Chen <rongliang.chan at gmail.com>wrote:
> That is an overflow somewhere. You can probably get the right answer by
>> using -snes_view. I will try and track down this overflow.
>> Matt
> Hi Matt,
> Thank you for your reply.
> The -snes_view and -log_summary output is followed. But I did not find any
> unusual results in the -snes_view output.
Yes, there was no overflow for individual matrices, so this output is
correct. The -log_summary output is for all
matrices, and that is the problem.
> I have another question. what the number 23 mean in the following
> -log_summary output:
> " Object Type Creations Destructions Memory Descendants'
> Mem.
> Reports information only for process 0.
> --- Event Stage 0: Main Stage
> Matrix 23 23 18446744073922240512 0 "
> Does it mean that I created 23 matrices in my code? But I think I have not
> created so many
> matrices. Thanks.
You might have created them, but we are counting all matrices, for instance
those created for
subdomain preconditioning.
Matt
> Best,
> Rongliang
> Starting to load grid...
> Nodes on moving boundary: coarse 199, fine 799, Gridratio 0.250000.
> Setupping Interpolation matrix......
> Interpolation matrix done......Time spent: 0.207468
> finished.
> Grid has 32000 elements, 1096658 degrees of freedom.
> Coarse grid has 2000 elements, 70170 degrees of freedom.
> [0] has 9234 degrees of freedom (matrix), 9234 degrees of freedom
> (including shared points).
> [0] coarse grid has 484 degrees of freedom (matrix), 484 degrees of
> freedom (including shared points).
> [127] has 7876 degrees of freedom (matrix), 9100 degrees of freedom
> [127] coarse grid has 588 degrees of freedom (matrix), 912 degrees of
> Time spend on the load grid and create matrix etc.: 3.719866.
> Solving Shape Optimization problem (steady-state problem)
> Solving coarse problem......
> 0 SNES norm 3.4998054301e+01, 0 KSP its last norm 0.0000000000e+00.
> 1 SNES norm 3.1501179205e+01, 34 KSP its last norm 3.3927102450e-01.
> 2 SNES norm 2.1246874435e+01, 57 KSP its last norm 3.1177722630e-01.
> 3 SNES norm 1.7390263296e+01, 141 KSP its last norm 1.9452289323e-01.
> 4 SNES norm 1.1644760718e+01, 160 KSP its last norm 1.6835316856e-01.
> 5 SNES norm 1.0601030093e+01, 181 KSP its last norm 1.1003156828e-01.
> 6 SNES norm 1.0145938759e+00, 126 KSP its last norm 1.0556059459e-01.
> 7 SNES norm 1.9267547420e-01, 203 KSP its last norm 9.9489004947e-03.
> 8 SNES norm 1.8901340973e-03, 195 KSP its last norm 1.8359299380e-03.
> Coarse solver done......
> Optimized value of object function (Energy dissipation) (Coarse):
> 29.9743671231
> The reduction of the energy dissipation (Coarse): -inf%
> The optimized curve (Coarse):
> a = (4.500000, -0.042961, -0.002068, 0.043750, -0.018783, 0.001816)
> Solving moving mesh equation......
> KSP norm 2.2906632201e-07, KSP its. 741. Time spent 2.772948
> Moving mesh solver done.
> 0 SNES norm 4.7914118974e+02, 0 KSP its last norm 0.0000000000e+00.
> 1 SNES norm 1.0150289152e+02, 63 KSP its last norm 4.6576374323e-01.
> 2 SNES norm 1.8326417396e+00, 90 KSP its last norm 9.9707541310e-02.
> 3 SNES norm 3.7711809663e-03, 348 KSP its last norm 1.8059473115e-03.
> 4 SNES norm 9.7342448527e-06, 484 KSP its last norm 3.6343704479e-06.
> SNES Object: 128 MPI processes
> type: ls
> line search variant: SNESLineSearchCubic
> alpha=1.000000000000e-04, maxstep=1.000000000000e+08,
> minlambda=1.000000000000e-12
> maximum iterations=20, maximum function evaluations=10000
> tolerances: relative=1e-06, absolute=1e-10, solution=1e-08
> total number of linear solver iterations=985
> total number of function evaluations=5
> KSP Object: 128 MPI processes
> type: gmres
> GMRES: restart=600, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> GMRES: happy breakdown tolerance 1e-30
> maximum iterations=3000, initial guess is zero
> tolerances: relative=0.001, absolute=1e-08, divergence=10000
> right preconditioning
> using UNPRECONDITIONED norm type for convergence test
> PC Object: 128 MPI processes
> type: asm
> Additive Schwarz: total subdomain blocks = 128, user-defined overlap
> Additive Schwarz: restriction/interpolation type - BASIC
> Local solve is same for all blocks, in the following KSP and PC
> objects:
> KSP Object: (sub_) 1 MPI processes
> type: preonly
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> left preconditioning
> using NONE norm type for convergence test
> PC Object: (sub_) 1 MPI processes
> type: lu
> LU: out-of-place factorization
> tolerance for zero pivot 1e-12
> using diagonal shift to prevent zero pivot
> matrix ordering: qmd
> factor fill ratio given 5, needed 5.26731
> Factored matrix follows:
> Matrix Object: 1 MPI processes
> type: seqaij
> rows=25170, cols=25170
> package used to perform factorization: petsc
> total: nonzeros=11090981, allocated nonzeros=11090981
> total number of mallocs used during MatSetValues calls =0
> using I-node routines: found 12872 nodes, limit used is 5
> linear system matrix = precond matrix:
> type: seqaij
> total: nonzeros=2105626, allocated nonzeros=2105626
> using I-node routines: found 13453 nodes, limit used is 5
> Matrix Object: 128 MPI processes
> type: mpiaij
> rows=1096658, cols=1096658
> total: nonzeros=94170314, allocated nonzeros=223806957
> total number of mallocs used during MatSetValues calls =6185057
> not using I-node (on process 0) routines
> Optimized value of object function (Energy dissipation) (Fine):
> 33.2754475059
> Solution time of 395.289169 sec.
> Number of unknowns = 1096658
> Parameters: kinematic viscosity = 0.01
> inlet velocity: u = 5, v = 0
> Total number of nonlinear iterations = 4
> Total number of linear iterations = 985
> Average number of linear iterations = 246.250000
> Time computing: 395.289169 sec, Time outputting: 0.000000 sec.
> Time spent in coarse nonlinear solve: 13.134366 sec, 0.033227 fraction of
> total compute time.
> The optimized curve (fine):
> a = (4.500000, -0.046466, -0.001962, 0.045734, -0.019141, 0.001789)
> The reduction of the energy dissipation (Fine): -inf%
> Time spend on fixed mesh solving: 0.013564
> Time spend on shape opt. solving: 395.324390
> Latex command line:
> np Newton GMRES Time(Total) Time(Coarse) Ratio
> 128 & 4 & 246.25 & 395.29 & 13.13 & 3.3\%
> Running finished on: Wed Oct 5 19:02:01 2011
> Total running time: 395.376442
> *** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r
> -fCourier9' to print this document ***
> ---------------------------------------------- PETSc Performance Summary:
> ./joab on a Janus-nod named node0844 with 128 processors, by ronglian Wed
> Oct 5 19:02:01 2011
> Using Petsc Release Version 3.2.0, Patch 1, Mon Sep 12 16:01:51 CDT 2011
> Max Max/Min Avg Total
> Time (sec): 3.991e+02 1.00013 3.991e+02
> Objects: 1.066e+03 1.00000 1.066e+03
> Flops: 7.938e+10 2.52133 5.615e+10 7.187e+12
> Flops/sec: 1.989e+08 2.52100 1.407e+08 1.801e+10
> MPI Messages: 2.724e+05 8.91400 6.158e+04 7.883e+06
> MPI Message Lengths: 8.340e+08 2.63753 1.025e+04 8.083e+10
> MPI Reductions: 6.537e+03 1.00000
> Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
> e.g., VecAXPY() for real vectors of length N
> --> 2N flops
> and VecAXPY() for complex vectors of length N
> --> 8N flops
> Summary of Stages: ----- Time ------ ----- Flops ----- --- Messages
> --- -- Message Lengths -- -- Reductions --
> Avg %Total Avg %Total counts
> %Total Avg %Total counts %Total
> 0: Main Stage: 3.9910e+02 100.0% 7.1875e+12 100.0% 7.883e+06
> 100.0% 1.025e+04 100.0% 6.536e+03 100.0%
> See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> Phase summary info:
> Count: number of times phase was executed
> Time and Flops: Max - maximum over all processors
> Ratio - ratio of maximum to minimum over all processors
> Mess: number of messages sent
> Avg. len: average message length
> Reduct: number of global reductions
> Global: entire computation
> Stage: stages of a computation. Set stages with PetscLogStagePush() and
> PetscLogStagePop().
> %T - percent time in this phase %F - percent flops in this
> phase
> %M - percent messages in this phase %L - percent message lengths
> in this phase
> %R - percent reductions in this phase
> Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over
> all processors)
> Event Count Time (sec)
> Flops --- Global --- --- Stage --- Total
> Max Ratio Max Ratio Max Ratio Mess Avg len
> Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
> MatMult 2879 1.0 4.3698e+0116.7 1.86e+09 1.3 2.1e+06 1.4e+03
> 0.0e+00 4 3 27 4 0 4 3 27 4 0 4839
> MatMultTranspose 3 1.0 3.0989e-0226.2 9.81e+05 1.2 2.0e+03 7.3e+02
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 3646
> MatSolve 2860 1.0 7.2956e+01 2.3 3.95e+10 2.5 0.0e+00 0.0e+00
> 0.0e+00 14 52 0 0 0 14 52 0 0 0 50895
> MatLUFactorSym 2 1.0 1.3847e+00 4.7 0.00e+00 0.0 0.0e+00 0.0e+00
> 6.0e+00 0 0 0 0 0 0 0 0 0 0 0
> MatLUFactorNum 13 1.0 4.9187e+01 5.8 3.56e+10 4.8 0.0e+00 0.0e+00
> 0.0e+00 5 33 0 0 0 5 33 0 0 0 48174
> MatILUFactorSym 1 1.0 3.9380e-03 3.3 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.0e+00 0 0 0 0 0 0 0 0 0 0 0
> MatAssemblyBegin 78 1.0 8.7529e+0129.0 0.00e+00 0.0 4.3e+04 5.2e+04
> 1.3e+02 11 0 1 3 2 11 0 1 3 2 0
> MatAssemblyEnd 78 1.0 7.2215e+00 1.0 0.00e+00 0.0 8.5e+03 3.6e+02
> 1.1e+02 2 0 0 0 2 2 0 0 0 2 0
> MatGetRowIJ 3 1.0 4.3902e-02 8.3 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> MatGetSubMatrice 13 1.0 1.9239e+00 2.9 0.00e+00 0.0 7.9e+04 1.8e+05
> 5.1e+01 0 0 1 17 1 0 0 1 17 1 0
> MatGetOrdering 3 1.0 4.1121e-01 3.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.0e+01 0 0 0 0 0 0 0 0 0 0 0
> MatPartitioning 1 1.0 2.2540e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatZeroEntries 32 1.0 3.8607e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
> MatView 3 3.0 1.6980e-0323.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecDot 12 1.0 6.8195e-0317.5 8.36e+04 1.2 0.0e+00 0.0e+00
> 1.2e+01 0 0 0 0 0 0 0 0 0 0 1451
> VecMDot 2823 1.0 4.1334e+01 7.2 3.82e+09 1.2 0.0e+00 0.0e+00
> 2.8e+03 4 6 0 0 43 4 6 0 0 43 10682
> VecNorm 2888 1.0 2.5551e+00 3.1 3.47e+07 1.2 0.0e+00 0.0e+00
> 2.9e+03 0 0 0 0 44 0 0 0 0 44 1575
> VecScale 2860 1.0 2.0850e-02 1.9 1.73e+07 1.2 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 96028
> VecCopy 117 1.0 2.1448e-03 2.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecSet 5795 1.0 2.2957e-01 2.5 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAXPY 116 1.0 1.9181e-03 1.6 1.36e+06 1.2 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 82341
> VecWAXPY 16 1.0 2.6107e-04 1.5 4.61e+04 1.2 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 21104
> VecMAXPY 2860 1.0 5.2077e+00 1.5 3.85e+09 1.2 0.0e+00 0.0e+00
> 0.0e+00 1 6 0 0 0 1 6 0 0 0 85546
> VecAssemblyBegin 60 1.0 3.4554e-0110.6 0.00e+00 0.0 1.8e+04 3.4e+02
> 1.8e+02 0 0 0 0 3 0 0 0 0 3 0
> VecAssemblyEnd 60 1.0 1.9860e-04 3.4 0.00e+00 0.0 0.0e+00 0.0e+00
> VecScatterBegin 8648 1.0 1.1008e+00 3.0 0.00e+00 0.0 7.7e+06 8.4e+03
> 0.0e+00 0 0 98 80 0 0 0 98 80 0 0
> VecScatterEnd 8648 1.0 8.4154e+0135.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 10 0 0 0 0 10 0 0 0 0 0
> VecReduceArith 4 1.0 2.6989e-04 2.3 4.00e+04 1.2 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 17292
> VecReduceComm 2 1.0 2.7108e-04 6.3 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.0e+00 0 0 0 0 0 0 0 0 0 0 0
> VecNormalize 2860 1.0 2.5307e+00 3.1 5.17e+07 1.2 0.0e+00 0.0e+00
> 2.8e+03 0 0 0 0 44 0 0 0 0 44 2370
> SNESSolve 2 1.0 3.9251e+02 1.0 7.85e+10 2.6 6.7e+06 9.7e+03
> 4.7e+03 98 98 84 80 72 98 98 84 80 72 18034
> SNESLineSearch 12 1.0 3.0610e+00 1.0 1.26e+07 1.2 6.1e+04 1.1e+04
> 2.9e+02 1 0 1 1 4 1 0 1 1 4 473
> SNESFunctionEval 18 1.0 6.5305e+00 1.0 6.01e+06 1.2 6.2e+04 1.3e+04
> 2.9e+02 2 0 1 1 4 2 0 1 1 4 106
> SNESJacobianEval 12 1.0 2.4492e+02 1.0 0.00e+00 0.0 2.5e+04 5.9e+04
> 9.0e+01 61 0 0 2 1 61 0 0 2 1 0
> KSPGMRESOrthog 2823 1.0 4.6476e+01 4.3 7.64e+09 1.2 0.0e+00 0.0e+00
> 2.8e+03 5 12 0 0 43 5 12 0 0 43 19001
> KSPSetup 26 1.0 1.3622e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
> KSPSolve 13 1.0 1.4371e+02 1.0 7.94e+10 2.5 7.8e+06 1.0e+04
> 5.8e+03 36100 98 97 88 36100 98 97 88 50001
> PCSetUp 26 1.0 5.2544e+01 5.3 3.56e+10 4.8 8.5e+04 1.7e+05
> 9.8e+01 6 33 1 17 1 6 33 1 17 1 45097
> PCSetUpOnBlocks 13 1.0 5.0695e+01 5.7 3.56e+10 4.8 0.0e+00 0.0e+00
> 1.7e+01 6 33 0 0 0 6 33 0 0 0 46742
> PCApply 2860 1.0 1.1268e+02 1.8 3.95e+10 2.5 5.6e+06 1.1e+04
> 0.0e+00 20 52 71 76 0 20 52 71 76 0 32953
> Memory usage is given in bytes:
> Object Type Creations Destructions Memory Descendants' Mem.
> Matrix Partitioning 1 1 640 0
> Index Set 168 168 922496 0
> IS L to G Mapping 2 2 78872 0
> Vector 828 828 44121632 0
> Vector Scatter 23 23 24196 0
> Application Order 2 2 9335968 0
> SNES 3 2 2544 0
> Krylov Solver 7 6 16141840 0
> Preconditioner 7 6 5456 0
> Viewer 2 1 712 0
> Average time to get PetscTime(): 9.53674e-08
> Average time for MPI_Barrier(): 2.36034e-05
> Average time for zero size MPI_Send(): 2.78279e-06
> #PETSc Option Table entries:
> -coarse_ksp_rtol 1.0e-1
> -coarsegrid
> /scratch/stmp00/ronglian/input/Cannula/Cannula_Nest2_E2000_N8241_D70170.fsi
> -f
> /scratch/stmp00/ronglian/input/Cannula/Cannula_Nest2_E32000_N128961_D1096650.fsi
> -geometric_asm
> -geometric_asm_overlap 8
> -inletu 5.0
> -ksp_atol 1e-8
> -ksp_gmres_restart 600
> -ksp_max_it 3000
> -ksp_pc_side right
> -ksp_rtol 1.e-3
> -ksp_type gmres
> -log_summary
> -mat_partitioning_type parmetis
> -nest_geometric_asm_overlap 4
> -nest_ksp_atol 1e-8
> -nest_ksp_gmres_restart 800
> -nest_ksp_max_it 1000
> -nest_ksp_pc_side right
> -nest_ksp_rtol 1.e-2
> -nest_ksp_type gmres
> -nest_pc_asm_type basic
> -nest_pc_type asm
> -nest_snes_atol 1.e-10
> -nest_snes_max_it 20
> -nest_snes_rtol 1.e-4
> -nest_sub_pc_factor_mat_ordering_type qmd
> -nest_sub_pc_factor_shift_amount 1e-8
> -nest_sub_pc_factor_shift_type nonzero
> -nest_sub_pc_type lu
> -nested
> -noboundaryreduce
> -pc_asm_type basic
> -pc_type asm
> -shapebeta 10.0
> -snes_atol 1.e-10
> -snes_max_it 20
> -snes_rtol 1.e-6
> -snes_view
> -sub_pc_factor_mat_ordering_type qmd
> -sub_pc_factor_shift_amount 1e-8
> -sub_pc_factor_shift_type nonzero
> -sub_pc_type lu
> -viscosity 0.01
> #End of PETSc Option Table entries
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
> sizeof(PetscScalar) 8
> Configure run at: Tue Sep 13 13:28:48 2011
> Configure options: --known-level1-dcache-size=32768
> --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0
> --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8
> --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8
> --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8
> --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=8
> --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-batch=1
> --with-mpi-shared-libraries=1 --known-mpi-shared-libraries=0
> --download-f-blas-lapack=1 --download-hypre=1 --download-superlu=1
> --download-parmetis=1 --download-superlu_dist=1 --download-blacs=1
> --download-scalapack=1 --download-mumps=1 --with-debugging=0
> Libraries compiled on Tue Sep 13 13:28:48 2011 on node1367
> Machine characteristics:
> Linux-2.6.18-238.12.1.el5-x86_64-with-redhat-5.6-Tikanga
> Using PETSc directory: /home/ronglian/soft/petsc-3.2-p1
> Using PETSc arch: Janus-nodebug
> Using C compiler: mpicc -Wall -Wwrite-strings -Wno-strict-aliasing
> -Wno-unknown-pragmas -O ${COPTFLAGS} ${CFLAGS}
> Using Fortran compiler: mpif90 -Wall -Wno-unused-variable -O
> ${FOPTFLAGS} ${FFLAGS}
> Using include paths:
> -I/home/ronglian/soft/petsc-3.2-p1/Janus-nodebug/include
> -I/home/ronglian/soft/petsc-3.2-p1/include
> -I/curc/tools/free/redhat_5_x86_64/openmpi-1.4.3_ib/include
> Using C linker: mpicc
> Using Fortran linker: mpif90
> Using libraries:
> -Wl,-rpath,/home/ronglian/soft/petsc-3.2-p1/Janus-nodebug/lib
> -L/home/ronglian/soft/petsc-3.2-p1/Janus-nodebug/lib -lpetsc -lX11
> -L/home/ronglian/soft/petsc-3.2-p1/Janus-nodebug/lib -lsuperlu_dist_2.5
> -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lparmetis -lmetis
> -lHYPRE -lmpi_cxx -lstdc++ -lscalapack -lblacs -lsuperlu_4.2 -lflapack
> -lfblas -L/curc/tools/free/redhat_5_x86_64/openmpi-1.4.3_ib/lib
> -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -ldl -lmpi -lopen-rte -lopen-pal
> -lnsl -lutil -lgcc_s -lpthread -lmpi_f90 -lmpi_f77 -lgfortran -lm -lm -lm
> -lm -lmpi_cxx -lstdc++ -lmpi_cxx -lstdc++ -ldl -lmpi -lopen-rte -lopen-pal
> -lnsl -lutil -lgcc_s -lpthread -ldl
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111006/e9370806/attachment-0001.htm>
