[petsc-users] Memory problem
Rongliang Chen rongliang.chan at gmail.com
Thu Oct 6 10:27:59 CDT 2011
   That is an overflow somewhere. You can probably get the right answer by
> using -snes_view. I will try and track down this overflow.
>   Matt
Hi Matt,
Thank you for your reply.
The -snes_view and -log_summary output is followed. But I did not find any
unusual results in the -snes_view output.
I have another question. what the number 23 mean in the following
-log_summary output:
" Object Type          Creations   Destructions     Memory  Descendants'
Mem.
Reports information only for process 0.
--- Event Stage 0: Main Stage
              Matrix    23             23  18446744073922240512     0 "
Does it mean that I created 23 matrices in my code? But I think I have not
created so many
matrices. Thanks.
Best,
Rongliang
Starting to load grid...
 Nodes on moving boundary: coarse 199, fine 799, Gridratio 0.250000.
Setupping Interpolation matrix......
Interpolation matrix done......Time spent: 0.207468
finished.
Grid has 32000 elements, 1096658 degrees of freedom.
Coarse grid has 2000 elements, 70170 degrees of freedom.
  [0] has 9234 degrees of freedom (matrix), 9234 degrees of freedom
(including shared points).
  [0] coarse grid has 484 degrees of freedom (matrix), 484 degrees of
freedom (including shared points).
  [127] has 7876 degrees of freedom (matrix), 9100 degrees of freedom
  [127] coarse grid has 588 degrees of freedom (matrix), 912 degrees of
Time spend on the load grid and create matrix etc.: 3.719866.
Solving Shape Optimization problem (steady-state problem)
Solving coarse problem......
  0 SNES norm 3.4998054301e+01, 0 KSP its last norm 0.0000000000e+00.
  1 SNES norm 3.1501179205e+01, 34 KSP its last norm 3.3927102450e-01.
  2 SNES norm 2.1246874435e+01, 57 KSP its last norm 3.1177722630e-01.
  3 SNES norm 1.7390263296e+01, 141 KSP its last norm 1.9452289323e-01.
  4 SNES norm 1.1644760718e+01, 160 KSP its last norm 1.6835316856e-01.
  5 SNES norm 1.0601030093e+01, 181 KSP its last norm 1.1003156828e-01.
  6 SNES norm 1.0145938759e+00, 126 KSP its last norm 1.0556059459e-01.
  7 SNES norm 1.9267547420e-01, 203 KSP its last norm 9.9489004947e-03.
  8 SNES norm 1.8901340973e-03, 195 KSP its last norm 1.8359299380e-03.
Coarse solver done......
Optimized value of object function (Energy dissipation) (Coarse):
29.9743671231
The reduction of the energy dissipation (Coarse): -inf%
The optimized curve (Coarse):
 a = (4.500000, -0.042961, -0.002068, 0.043750, -0.018783, 0.001816)
Solving  moving mesh equation......
 KSP norm 2.2906632201e-07, KSP its. 741. Time spent 2.772948
Moving mesh solver done.
  0 SNES norm 4.7914118974e+02, 0 KSP its last norm 0.0000000000e+00.
  1 SNES norm 1.0150289152e+02, 63 KSP its last norm 4.6576374323e-01.
  2 SNES norm 1.8326417396e+00, 90 KSP its last norm 9.9707541310e-02.
  3 SNES norm 3.7711809663e-03, 348 KSP its last norm 1.8059473115e-03.
  4 SNES norm 9.7342448527e-06, 484 KSP its last norm 3.6343704479e-06.
SNES Object: 128 MPI processes
  type: ls
    line search variant: SNESLineSearchCubic
    alpha=1.000000000000e-04, maxstep=1.000000000000e+08,
minlambda=1.000000000000e-12
  maximum iterations=20, maximum function evaluations=10000
  tolerances: relative=1e-06, absolute=1e-10, solution=1e-08
  total number of linear solver iterations=985
  total number of function evaluations=5
  KSP Object:   128 MPI processes
    type: gmres
      GMRES: restart=600, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
      GMRES: happy breakdown tolerance 1e-30
    maximum iterations=3000, initial guess is zero
    tolerances:  relative=0.001, absolute=1e-08, divergence=10000
    right preconditioning
    using UNPRECONDITIONED norm type for convergence test
  PC Object:   128 MPI processes
    type: asm
      Additive Schwarz: total subdomain blocks = 128, user-defined overlap
      Additive Schwarz: restriction/interpolation type - BASIC
      Local solve is same for all blocks, in the following KSP and PC
objects:
    KSP Object:    (sub_)     1 MPI processes
      type: preonly
      maximum iterations=10000, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
      left preconditioning
      using NONE norm type for convergence test
    PC Object:    (sub_)     1 MPI processes
      type: lu
        LU: out-of-place factorization
        tolerance for zero pivot 1e-12
        using diagonal shift to prevent zero pivot
        matrix ordering: qmd
        factor fill ratio given 5, needed 5.26731
          Factored matrix follows:
            Matrix Object:             1 MPI processes
              type: seqaij
              rows=25170, cols=25170
              package used to perform factorization: petsc
              total: nonzeros=11090981, allocated nonzeros=11090981
              total number of mallocs used during MatSetValues calls =0
                using I-node routines: found 12872 nodes, limit used is 5
      linear system matrix = precond matrix:
        type: seqaij
        total: nonzeros=2105626, allocated nonzeros=2105626
          using I-node routines: found 13453 nodes, limit used is 5
    Matrix Object:     128 MPI processes
      type: mpiaij
      rows=1096658, cols=1096658
      total: nonzeros=94170314, allocated nonzeros=223806957
      total number of mallocs used during MatSetValues calls =6185057
        not using I-node (on process 0) routines
Optimized value of object function (Energy dissipation) (Fine):
33.2754475059
Solution time of 395.289169 sec.
Number of unknowns = 1096658
Parameters: kinematic viscosity = 0.01
            inlet velocity: u = 5,  v = 0
Total number of nonlinear iterations = 4
Total number of linear iterations = 985
Average number of linear iterations = 246.250000
Time computing: 395.289169 sec, Time outputting: 0.000000 sec.
Time spent in coarse nonlinear solve: 13.134366 sec, 0.033227 fraction of
total compute time.
The optimized curve (fine):
 a = (4.500000, -0.046466, -0.001962, 0.045734, -0.019141, 0.001789)
The reduction of the energy dissipation (Fine): -inf%
Time spend on fixed mesh solving: 0.013564
Time spend on shape opt. solving: 395.324390
Latex command line:
  np    Newton   GMRES   Time(Total)    Time(Coarse)   Ratio
 128 &   4   &   246.25   &   395.29  &    13.13   &  3.3\%
Running finished on: Wed Oct  5 19:02:01 2011
Total running time: 395.376442
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r
-fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary:
./joab on a Janus-nod named node0844 with 128 processors, by ronglian Wed
Oct  5 19:02:01 2011
Using Petsc Release Version 3.2.0, Patch 1, Mon Sep 12 16:01:51 CDT 2011
                         Max       Max/Min        Avg      Total
Time (sec):           3.991e+02      1.00013   3.991e+02
Objects:              1.066e+03      1.00000   1.066e+03
Flops:                7.938e+10      2.52133   5.615e+10  7.187e+12
Flops/sec:            1.989e+08      2.52100   1.407e+08  1.801e+10
MPI Messages:         2.724e+05      8.91400   6.158e+04  7.883e+06
MPI Message Lengths:  8.340e+08      2.63753   1.025e+04  8.083e+10
MPI Reductions:       6.537e+03      1.00000
Flop counting convention: 1 flop = 1 real number operation of type
(multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N -->
2N flops
                            and VecAXPY() for complex vectors of length N
--> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---
-- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts
%Total     Avg         %Total   counts   %Total
 0:      Main Stage: 3.9910e+02 100.0%  7.1875e+12 100.0%  7.883e+06 100.0%
1.025e+04      100.0%  6.536e+03 100.0%
See the 'Profiling' chapter of the users' manual for details on interpreting
output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and
PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this
phase
      %M - percent messages in this phase     %L - percent message lengths
in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over
all processors)
Event                Count      Time (sec)
Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
MatMult             2879 1.0 4.3698e+0116.7 1.86e+09 1.3 2.1e+06 1.4e+03
0.0e+00  4  3 27  4  0   4  3 27  4  0  4839
MatMultTranspose       3 1.0 3.0989e-0226.2 9.81e+05 1.2 2.0e+03 7.3e+02
0.0e+00  0  0  0  0  0   0  0  0  0  0  3646
MatSolve            2860 1.0 7.2956e+01 2.3 3.95e+10 2.5 0.0e+00 0.0e+00
0.0e+00 14 52  0  0  0  14 52  0  0  0 50895
MatLUFactorSym         2 1.0 1.3847e+00 4.7 0.00e+00 0.0 0.0e+00 0.0e+00
6.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum        13 1.0 4.9187e+01 5.8 3.56e+10 4.8 0.0e+00 0.0e+00
0.0e+00  5 33  0  0  0   5 33  0  0  0 48174
MatILUFactorSym        1 1.0 3.9380e-03 3.3 0.00e+00 0.0 0.0e+00 0.0e+00
1.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin      78 1.0 8.7529e+0129.0 0.00e+00 0.0 4.3e+04 5.2e+04
1.3e+02 11  0  1  3  2  11  0  1  3  2     0
MatAssemblyEnd        78 1.0 7.2215e+00 1.0 0.00e+00 0.0 8.5e+03 3.6e+02
1.1e+02  2  0  0  0  2   2  0  0  0  2     0
MatGetRowIJ            3 1.0 4.3902e-02 8.3 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice      13 1.0 1.9239e+00 2.9 0.00e+00 0.0 7.9e+04 1.8e+05
5.1e+01  0  0  1 17  1   0  0  1 17  1     0
MatGetOrdering         3 1.0 4.1121e-01 3.5 0.00e+00 0.0 0.0e+00 0.0e+00
1.0e+01  0  0  0  0  0   0  0  0  0  0     0
MatPartitioning        1 1.0 2.2540e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatZeroEntries        32 1.0 3.8607e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
MatView                3 3.0 1.6980e-0323.0 0.00e+00 0.0 0.0e+00 0.0e+00
VecDot                12 1.0 6.8195e-0317.5 8.36e+04 1.2 0.0e+00 0.0e+00
1.2e+01  0  0  0  0  0   0  0  0  0  0  1451
VecMDot             2823 1.0 4.1334e+01 7.2 3.82e+09 1.2 0.0e+00 0.0e+00
2.8e+03  4  6  0  0 43   4  6  0  0 43 10682
VecNorm             2888 1.0 2.5551e+00 3.1 3.47e+07 1.2 0.0e+00 0.0e+00
2.9e+03  0  0  0  0 44   0  0  0  0 44  1575
VecScale            2860 1.0 2.0850e-02 1.9 1.73e+07 1.2 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0 96028
VecCopy              117 1.0 2.1448e-03 2.0 0.00e+00 0.0 0.0e+00 0.0e+00
VecSet              5795 1.0 2.2957e-01 2.5 0.00e+00 0.0 0.0e+00 0.0e+00
VecAXPY              116 1.0 1.9181e-03 1.6 1.36e+06 1.2 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0 82341
VecWAXPY              16 1.0 2.6107e-04 1.5 4.61e+04 1.2 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0 21104
VecMAXPY            2860 1.0 5.2077e+00 1.5 3.85e+09 1.2 0.0e+00 0.0e+00
0.0e+00  1  6  0  0  0   1  6  0  0  0 85546
VecAssemblyBegin      60 1.0 3.4554e-0110.6 0.00e+00 0.0 1.8e+04 3.4e+02
1.8e+02  0  0  0  0  3   0  0  0  0  3     0
VecAssemblyEnd        60 1.0 1.9860e-04 3.4 0.00e+00 0.0 0.0e+00 0.0e+00
VecScatterBegin     8648 1.0 1.1008e+00 3.0 0.00e+00 0.0 7.7e+06 8.4e+03
0.0e+00  0  0 98 80  0   0  0 98 80  0     0
VecScatterEnd       8648 1.0 8.4154e+0135.5 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 10  0  0  0  0  10  0  0  0  0     0
VecReduceArith         4 1.0 2.6989e-04 2.3 4.00e+04 1.2 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0 17292
VecReduceComm          2 1.0 2.7108e-04 6.3 0.00e+00 0.0 0.0e+00 0.0e+00
2.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize        2860 1.0 2.5307e+00 3.1 5.17e+07 1.2 0.0e+00 0.0e+00
2.8e+03  0  0  0  0 44   0  0  0  0 44  2370
SNESSolve              2 1.0 3.9251e+02 1.0 7.85e+10 2.6 6.7e+06 9.7e+03
4.7e+03 98 98 84 80 72  98 98 84 80 72 18034
SNESLineSearch        12 1.0 3.0610e+00 1.0 1.26e+07 1.2 6.1e+04 1.1e+04
2.9e+02  1  0  1  1  4   1  0  1  1  4   473
SNESFunctionEval      18 1.0 6.5305e+00 1.0 6.01e+06 1.2 6.2e+04 1.3e+04
2.9e+02  2  0  1  1  4   2  0  1  1  4   106
SNESJacobianEval      12 1.0 2.4492e+02 1.0 0.00e+00 0.0 2.5e+04 5.9e+04
9.0e+01 61  0  0  2  1  61  0  0  2  1     0
KSPGMRESOrthog      2823 1.0 4.6476e+01 4.3 7.64e+09 1.2 0.0e+00 0.0e+00
2.8e+03  5 12  0  0 43   5 12  0  0 43 19001
KSPSetup              26 1.0 1.3622e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSolve              13 1.0 1.4371e+02 1.0 7.94e+10 2.5 7.8e+06 1.0e+04
5.8e+03 36100 98 97 88  36100 98 97 88 50001
PCSetUp               26 1.0 5.2544e+01 5.3 3.56e+10 4.8 8.5e+04 1.7e+05
9.8e+01  6 33  1 17  1   6 33  1 17  1 45097
PCSetUpOnBlocks       13 1.0 5.0695e+01 5.7 3.56e+10 4.8 0.0e+00 0.0e+00
1.7e+01  6 33  0  0  0   6 33  0  0  0 46742
PCApply             2860 1.0 1.1268e+02 1.8 3.95e+10 2.5 5.6e+06 1.1e+04
0.0e+00 20 52 71 76  0  20 52 71 76  0 32953
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
 Matrix Partitioning     1              1          640     0
           Index Set   168            168       922496     0
   IS L to G Mapping     2              2        78872     0
              Vector   828            828     44121632     0
      Vector Scatter    23             23        24196     0
   Application Order     2              2      9335968     0
                SNES     3              2         2544     0
       Krylov Solver     7              6     16141840     0
      Preconditioner     7              6         5456     0
              Viewer     2              1          712     0
Average time to get PetscTime(): 9.53674e-08
Average time for MPI_Barrier(): 2.36034e-05
Average time for zero size MPI_Send(): 2.78279e-06
#PETSc Option Table entries:
-coarse_ksp_rtol 1.0e-1
-coarsegrid
/scratch/stmp00/ronglian/input/Cannula/Cannula_Nest2_E2000_N8241_D70170.fsi
-f
/scratch/stmp00/ronglian/input/Cannula/Cannula_Nest2_E32000_N128961_D1096650.fsi
-geometric_asm
-geometric_asm_overlap 8
-inletu 5.0
-ksp_atol 1e-8
-ksp_gmres_restart 600
-ksp_max_it 3000
-ksp_pc_side right
-ksp_rtol 1.e-3
-ksp_type gmres
-log_summary
-mat_partitioning_type parmetis
-nest_geometric_asm_overlap 4
-nest_ksp_atol 1e-8
-nest_ksp_gmres_restart 800
-nest_ksp_max_it 1000
-nest_ksp_pc_side right
-nest_ksp_rtol 1.e-2
-nest_ksp_type gmres
-nest_pc_asm_type basic
-nest_pc_type asm
-nest_snes_atol 1.e-10
-nest_snes_max_it 20
-nest_snes_rtol 1.e-4
-nest_sub_pc_factor_mat_ordering_type qmd
-nest_sub_pc_factor_shift_amount 1e-8
-nest_sub_pc_factor_shift_type nonzero
-nest_sub_pc_type lu
-nested
-noboundaryreduce
-pc_asm_type basic
-pc_type asm
-shapebeta 10.0
-snes_atol 1.e-10
-snes_max_it 20
-snes_rtol 1.e-6
-snes_view
-sub_pc_factor_mat_ordering_type qmd
-sub_pc_factor_shift_amount 1e-8
-sub_pc_factor_shift_type nonzero
-sub_pc_type lu
-viscosity 0.01
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
sizeof(PetscScalar) 8
Configure run at: Tue Sep 13 13:28:48 2011
Configure options: --known-level1-dcache-size=32768
--known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0
--known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8
--known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8
--known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8
--known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=8
--known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-batch=1
--with-mpi-shared-libraries=1 --known-mpi-shared-libraries=0
--download-f-blas-lapack=1 --download-hypre=1 --download-superlu=1
--download-parmetis=1 --download-superlu_dist=1 --download-blacs=1
--download-scalapack=1 --download-mumps=1 --with-debugging=0
Libraries compiled on Tue Sep 13 13:28:48 2011 on node1367
Machine characteristics:
Linux-2.6.18-238.12.1.el5-x86_64-with-redhat-5.6-Tikanga
Using PETSc directory: /home/ronglian/soft/petsc-3.2-p1
Using PETSc arch: Janus-nodebug
Using C compiler: mpicc  -Wall -Wwrite-strings -Wno-strict-aliasing
-Wno-unknown-pragmas -O  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -Wall -Wno-unused-variable -O   ${FOPTFLAGS}
${FFLAGS}
Using include paths:
-I/home/ronglian/soft/petsc-3.2-p1/Janus-nodebug/include
-I/home/ronglian/soft/petsc-3.2-p1/include
-I/curc/tools/free/redhat_5_x86_64/openmpi-1.4.3_ib/include
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries:
-Wl,-rpath,/home/ronglian/soft/petsc-3.2-p1/Janus-nodebug/lib
-L/home/ronglian/soft/petsc-3.2-p1/Janus-nodebug/lib -lpetsc -lX11
-L/home/ronglian/soft/petsc-3.2-p1/Janus-nodebug/lib -lsuperlu_dist_2.5
-lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lparmetis -lmetis
-lHYPRE -lmpi_cxx -lstdc++ -lscalapack -lblacs -lsuperlu_4.2 -lflapack
-lfblas -L/curc/tools/free/redhat_5_x86_64/openmpi-1.4.3_ib/lib
-L/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -ldl -lmpi -lopen-rte -lopen-pal
-lnsl -lutil -lgcc_s -lpthread -lmpi_f90 -lmpi_f77 -lgfortran -lm -lm -lm
-lm -lmpi_cxx -lstdc++ -lmpi_cxx -lstdc++ -ldl -lmpi -lopen-rte -lopen-pal
-lnsl -lutil -lgcc_s -lpthread -ldl
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111006/d18464b6/attachment-0001.htm>
