[petsc-users] How to get Matrix from MatGetArray()
Sat Oct 1 11:12:02 CDT 2011
On Sat, Oct 1, 2011 at 11:07 AM, behzad baghapour <
behzad.baghapour at gmail.com> wrote:
> Thanks, then i should change my idea abut matrix evaluation in Petsc. I
> will try to keep matrix in the same structure during successive iterations.
No, that is not the points at all. You should use the interface to alter the
matrix as you want. More directly,
  Give up on a[i[row]+offset[col]] = value;
and use instead
  MatSetValues(A, 1, &row, 1, &col, &value, INSERT_VALUES);
I strongly suggest you read
  http://dl.acm.org/citation.cfm?id=245883
      Matt
> On Sat, Oct 1, 2011 at 7:26 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sat, Oct 1, 2011 at 10:44 AM, behzad baghapour <
>>> OK. All I am concering is:
>>> 1- define matrix A in sparse format AIJ.
>>> 2- Get the content of A.
>>> 3- change the content of A for some elements
>>> 4- Restore the changed matrix back into origin.
>>> I test MatGetArray( Mat A, PetscScalar* a ) but I couldnt find the
>>> correct content of matrix by using a[i*n+j]. I need to know how to access
>>> the elements of an assembled sparse matrix.
>>> Am I clear now?
>> No, definitely do not do that. The whole point of PETSc matrices is that
>> you do not do this. This is what
>> is wrong with 90% of numerical software. You want *interfaces*, not data
>> structures. That allows you
>> to seamlessly
>>   - work in parallel
>>   - work on GPUs
>>   - optimize for different architectures
>> What you want to do is use MatSetValues() (or MatZeroRows, etc.) to change
>> your entries.
>>     Matt
>>> Thanks
>>> Behzad
>>> On Sat, Oct 1, 2011 at 6:56 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>>>  On Sat, Oct 1, 2011 at 10:23, behzad baghapour <
>>>>> I meant by MatAssembly, the global indices of matrix elements (related
>>>>> to a dense format) which is changed into sparse one.
>>>> I don't understand what you mean. It doesn't make sense to convert
>>>> "dense" indices into sparse ones.
>>>>> So what would be right pattern to read the content of the Matrix from
>>>>> MatGetArray if I know that the original matrix is created by AIJ?
>>>> Use MatGetRow() if you need access to this. (The internal data
>>>> structures are different in parallel and serial, so accessing them directly
>>>> is bad.)
>>> Behzad Baghapour
>>> Ph.D. Candidate, Mechecanical Engineering
>>> University of Tehran, Tehran, Iran
>>> https://sites.google.com/site/behzadbaghapour
>>> Fax: 0098-21-88020741
>> experiments lead.
>> -- Norbert Wiener
> Behzad Baghapour
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111001/6d6ddb25/attachment.htm>
