[petsc-users] How to get Matrix from MatGetArray()
behzad baghapour
behzad.baghapour at gmail.com
Sat Oct 1 11:07:44 CDT 2011
Thanks, then i should change my idea abut matrix evaluation in Petsc. I will
try to keep matrix in the same structure during successive iterations.
On Sat, Oct 1, 2011 at 7:26 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Oct 1, 2011 at 10:44 AM, behzad baghapour <
> behzad.baghapour at gmail.com> wrote:
>> OK. All I am concering is:
>> 1- define matrix A in sparse format AIJ.
>> 2- Get the content of A.
>> 3- change the content of A for some elements
>> 4- Restore the changed matrix back into origin.
>> I test MatGetArray( Mat A, PetscScalar* a ) but I couldnt find the correct
>> content of matrix by using a[i*n+j]. I need to know how to access the
>> elements of an assembled sparse matrix.
>> Am I clear now?
> No, definitely do not do that. The whole point of PETSc matrices is that
> you do not do this. This is what
> is wrong with 90% of numerical software. You want *interfaces*, not data
> structures. That allows you
> to seamlessly
> - work in parallel
> - work on GPUs
> - optimize for different architectures
> What you want to do is use MatSetValues() (or MatZeroRows, etc.) to change
> your entries.
> Matt
>> Thanks
>> Behzad
>> On Sat, Oct 1, 2011 at 6:56 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> On Sat, Oct 1, 2011 at 10:23, behzad baghapour <
>>>> I meant by MatAssembly, the global indices of matrix elements (related
>>>> to a dense format) which is changed into sparse one.
>>> I don't understand what you mean. It doesn't make sense to convert
>>> "dense" indices into sparse ones.
>>>> So what would be right pattern to read the content of the Matrix from
>>>> MatGetArray if I know that the original matrix is created by AIJ?
>>> Use MatGetRow() if you need access to this. (The internal data structures
>>> are different in parallel and serial, so accessing them directly is bad.)
>> Behzad Baghapour
>> Ph.D. Candidate, Mechecanical Engineering
>> University of Tehran, Tehran, Iran
>> https://sites.google.com/site/behzadbaghapour
>> Fax: 0098-21-88020741
> experiments lead.
> -- Norbert Wiener
Behzad Baghapour
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111001/14ff1768/attachment.htm>
