[petsc-users] is something wrong with nnz ?
jean-frederic thebault
jean-frederic at thebault-net.com
Wed Nov 23 09:55:20 CST 2011
Thanks for your response.
Sorry about that, to reduce the size of the log file, unfortunetly, I did
took out the bad lines... In the out.log I've put in this email, I've make
sure there are...
Actually, I don't use MatSetOption, but MatSetFromOption instead. However,
when I called MatSetFromOption, the PETSC_COMM_WORLD was missing. But now,
it's getting worse !! (as you could see in the out.log included in this
email).
Le 23 novembre 2011 15:55, Jed Brown <jedbrown at mcs.anl.gov> a écrit :
> On Wed, Nov 23, 2011 at 08:24, jean-frederic thebault <
> jean-frederic at thebault-net.com> wrote:
>> I'm wondering what's wrong in my code. I'm using PETSc to solve a linear
>> system, and willing to use a multi-processor computer. 9 years ago, I used
>> petsc-2.1.3 with success. Few weeks ago, I've update petsc with the 3.1-p8
>> version and made the necessary changes to work with. No problem. And
>> recently, I've migrate to petsc-3.2-p5. Compilation is OK. But when I do
>> simulation, now, I have some PETSC-ERROR in the log file, even using only
>> one processor (see the out.log file in this email).
> You are calling MatSetOption() with the wrong number of arguments. C
> compilers tell you about this, but Fortran compilers do not.
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetOption.html
>> However, I think I defined MatMPI and VecMPI correctly, according to the
>> doc. The log file tell that something wrong with the nnz which should not
>> be greater than row length (??).
> The log you sent does not say anything about nnz. Fix the call to
> MatSetOption().
> And also, with the previous version of PETSc I've used, the were no
>> problem using -pc_type bjacobi and -sub_pc_type sor, juste to solve linear
>> system doing parallel computations and because SOR is not parallelized. But
>> now, when I use -pc_type bjacobi and -sub_pc_type sor, with 3 rank, I
>> experiment some convergence problem during my simulation.
> These options should do the same thing they used to do. Make sure you are
> assembling correctly. If it's still confusing, run the old and new code with
> -ksp_monitor_true_residual -ksp_converged_reason -ksp_view -pc_type
> bjacobi -sub_pc_type sor
> and send the output of both for us to look at.
> Also note that you can use -pc_type sor even in parallel. There are
> options for local iterations and full iterations.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111123/c70300f3/attachment.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111123/c70300f3/attachment.obj>
