[petsc-users] sqrt: DOMAIN error during run
TAY wee-beng
zonexo at gmail.com
Tue Nov 22 02:37:25 CST 2011
Thanks Barry and Jed,
I found that the error is due to a divide by zero.
Some variables had zero values and were not calculated. Hence division
by these values gave NaN. Strangely, running thru the debugger gave zero
instead.
Yours sincerely,
TAY wee-beng
On 21/11/2011 8:33 PM, Barry Smith wrote:
> If it runs in one mode (like in a debugger) but crashes in another (like not in the debugger) this is often a symptom of memory corruption: http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> Barry
> On Nov 21, 2011, at 1:10 PM, TAY wee-beng wrote:
>> Hi,
>> I have extended my 2D CFD code to 3D.
>> When I tried to do a step by step debug using Compaq visual Fortran (CVF) in windows, there is no error.
>> However, if I execute the code directly, the following error happens:
>> - sqrt: DOMAIN error
>> Image PC Routine Line Source
>> ibm2d_high_Re_wo_ 00B95C69 Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 00B95AC7 Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 00B95C21 Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 00B9CEA8 Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 00BBF61D Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 00BB7E30 Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 00BB1B98 Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 00B79319 Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 0085C29A Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 0063C656 Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 008EC67D Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 005C95DC Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 00549D2C Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 00500BEE Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 00428FE3 Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 00463073 Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 00BC5309 Unknown Unknown Unknown
>> ibm2d_high_Re_wo_ 00BB1035 Unknown Unknown Unknown
>> kernel32.dll 7C817067 Unknown Unknown Unknown
>> Incrementally linked image--PC correlation disabled.
>> I repeated running the code in Linux and calling "KSPGetConvergedReason" gives:
>> P Diverged
>> Does anyone know why this error occurs? It's strange that the step by step debug works and gives a reasonable solution but executing the code gives error.
>> Also, when changing from 2D to 3D, is there any additional stuff I need to add in besides adding another dimension?
>> Yours sincerely,
>> TAY wee-beng
