[petsc-users] trouble installing petsc 3.1-p8 on centos 4.8
Thu Nov 17 10:59:41 CST 2011
Configure Options: --configModules=PETSc.Configure --optionsModule=PETSc.compilerOptions --with-shared --with-debugging=0 --with-batch --with-mpi-dir=/home/edward/MPM/openmpi-1.4.4/build2
> Must give a default value for known-mpi-shared since executables cannot be run
Well - as the message says - configure needs the user to tell it if
mpi libraries are shared or not. i.e specify -known-mpi-shared=1 [or
0]. When --with-batch option is used - configure can't do 'run tests'
to determin this itself.
But I think the primary issue is - the openmpi install is
broken. Hence you might gotten a message about - "can't run binaries -
suggest using --with-batch"
This is because oenmpi install is broken until you set the following
[as per openmpi installation instructions]
export LD_LIBRARY_PATH=/home/edward/MPM/openmpi-1.4.4/build2/lib
petsc-3.2 works arround this user-unfriendly feature.
Satish
On Thu, 17 Nov 2011, John Schmidt wrote:
> Hi,
> I have a collegue that is trying to install petsc 3.1-p8 on centos 4.8.
> Centos 4.8 is using the gcc-3.4.5 compilers.  He installed openmpi-1.4.4 and
> that seems to work with our Uintah software, however, he is having issues with
> the petsc build.  Attached is his configure.log that hopefully will help in
> diagnosing the problem.  Any help is greatly appreciated.
> Thanks,
> John Schmidt
> john.schmidt at utah.edu
