[petsc-users] Using petsc for banded matrices and 2D finite differences
Tue Nov 15 12:11:53 CST 2011
On Tue, Nov 15, 2011 at 12:03, Brandt Belson <bbelson at princeton.edu> wrote:
> I'm not sure what you mean by the sign of the shift, but the equations are
> roughly of the form:
> (I dt/Re - L) u = f
> where dt~0.1, Re~1000, and L is the Laplacian in 3D,
The time step size is in the numerator? (It's more commonly the other way.)
In any case, this is a positive shift, so you always have a positive
definite operator. Multigrid should work very well, so you shouldn't need
to bother with direct solvers.
> so once it is Fourier transformed each x-y plane has equations like this:
> (I dt/Re + I k_z^2 - L_{k_z}) \hat{u}_{k_z} = \hat{f}_{k_z}
> I'm not sure which wavenumber you mean, but k_z goes as nz.
It arises for frequency-domain problems where the shift is in the other
direction (producing an indefinite operator).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111115/84976aea/attachment.htm>
