[petsc-users] configure error windows debug mode
Dominik Szczerba
dominik at itis.ethz.ch
Tue Nov 15 08:49:55 CST 2011
On Tue, Nov 15, 2011 at 3:29 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 15 Nov 2011, Dominik Szczerba wrote:
>> > Did you see my previous reply to this issue? Looks like instead of
>> > trying this suggestion - you've assumed the problem was elsewere - and
>> > attempted a complete rebuild.
>> > Please invoke 'make' [with the correct PETSC_ARCH and PETSC_DIR] in
>> > the appropriate 'source' dir - where-ever you see 'vfork' error - to
>> > complete the build of those sources.
>> I saw it, I apologize I did not answer, but seeing the other error
>> (cmake error) made me think I better start completely fresh. Meanwhile
>> I tried the "rebase" hint that I found in the old archives. I will do
>> as you say the next time the error occurs and post an update.
> As mentioned in the 'prior-proir' message - the cmake message is
> misleading. The configure did complete - and print a nice summary of
> what its doing. Configure however decided to use the legacy build -
> instead of cmake buld - due to the cmake error.
> Note - you were using legacy build for both debug and optimized
> builds. If you see stuff like:
> libfast in: /cygdrive/c/pack/petsc-3.2-p5/src/mat/impls/adj
> Then you are using the non-cmake legacy build. [which is the fallback
> when cmake part of configure fails - for whatever reason]
> Satish
Just to be reproducible: how can I explicitly force the legacy build?
Or is it dying soon and I better switch now?
Is using cmake to build but not configure really simplifying things?
Thanks and regards,
Dominik
