[petsc-users] Need help...
Matthew Knepley
knepley at gmail.com
Tue Nov 8 10:45:22 CST 2011
On Tue, Nov 8, 2011 at 4:15 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Nov 8, 2011 at 10:09, jean-frederic thebault <
> jean-frederic at thebault-net.com> wrote:
>> First of all, thank you for this library.
>> View years ago, we had mixed our (f77) finite volume code with petsc, and
>> obtained some very interested results (faster calculations, multi-processor
>> issues, ..), with a 4 linux-PC cluster and a myrinet switch, and petsc-2.1.3
>> Regarding the new PC architecture (multi-threading), the same mixed code
>> apparently is calculating slower each time we increase the number of
>> processors used (processor or core, I'm not sure to use the right word). We
>> thought that time that we should upgrade our petsc library (with
>> petsc-3.1-p8)
> Please use petsc-3.2
>> to have benefit of the multi-threading architecture. So do we, changing a
>> little bit some stuff (merrely "include" names). We compiled it with
>> mpif77. The fortran-samples of petsc are working just fine. But our code
>> doesn't work. We have tried a lot of different options and tried for view
>> weeks to figure out what is happening, nothing.
There have been 11 releases of the 9 years since 2.1.3. There have been
more interface changes than MatSetOption(). All of them
are catalogued here:
http://www.mcs.anl.gov/petsc/petsc-as/documentation/changes/index.html.
"Doesn't work" is an inadequate
description of your problem. What happen precisely?
Matt
> The calling sequence for MatSetOption() has changed. You are likely
> calling it incorrectly.
> The compiler tells you about these things in C. Fortran 77 type checking
> is nonexistant so the compiler doesn't check these things. If you use F90
> or later, you can turn on interface definitions to get some rudimentary
> type checking. Type checking is much better in C.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111108/4f828415/attachment.htm>
