[petsc-users] SNES convergence issue
Jed Brown
jed at 59A2.org
Mon May 16 09:57:58 CDT 2011
On Mon, May 16, 2011 at 16:50, Tian(ICT) <rongtian at ncic.ac.cn> wrote:
> ./pgfem -pc_type none does not work either, leading to negative jacobian of
> element.
During finite differencing or in the line search? Perhaps a trust region
would be better for this problem.
What is the output for -mat_view, are all the output the jacobian, or do
> they inlcude preconditioning matrix?
It includes all matrices. You can call MatSetOptionsPrefix(B,"jacpre_") and
then run with -jacpre_mat_view to see only that matrix.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110516/205d7a39/attachment.htm>
