[petsc-users] It is posible to install petcs-3.1-p7 on window-intel-mkl plattform vers. 11.1-067
Barry Smith
bsmith at mcs.anl.gov
Thu Mar 24 07:33:20 CDT 2011
Don't spend hours trying random combinations of things. Instead run what you think you should work, then send the failed configure.log to petsc-maint at mcs.anl.gov We will suggest a new thing to try, run that again sending failed output to petsc-maint at mcs.anl.gov etc. But you must follow our suggestions for the "next try" or you will end up going around in circles and getting very frustrated.
Barry
On Mar 24, 2011, at 4:20 AM, Hung Thanh Nguyen wrote:
> Hi Petsc-use
> I’ve spent many hours for to install ( ./config/configure) Petcs petsc-3.1-p7 on window Intel mkl platform (Intel-Compiler-11.1-067-ia32). I try different ways to configure Petcs ( see the last email) and I got some value tips from PETSC- used. However, The configure option is still not working . Therefore, I am wondering Is it possible to run PETSc on Window Intel Mkl platform? If the answer is yes, so how and/or any where can I addressed myself for to get help. Thanks and
> Kind regards
> Hung T. Nguyen
> Research in Numerical Analys
> Norway
