[petsc-users] It is posible to install petcs-3.1-p7 on window-intel-mkl plattform vers. 11.1-067
Alexander Grayver agrayver at gfz-potsdam.de
Thu Mar 24 05:27:46 CDT 2011
Hi Hung,
Are you able to compile (using your Intel MKL platform) and run simple
programs within cygwin?
On 24.03.2011 10:20, Hung Thanh Nguyen wrote:
> Hi Petsc-use
> I've spent  many  hours  for to install ( ./config/configure) Petcs
> petsc-3.1-p7 on window Intel mkl platform
> (Intel-Compiler-11.1-067-ia32). I try different ways to configure
> Petcs ( see the last email) and I got some value tips from PETSC-
> used. However, The configure option is still  not working . Therefore,
> I am wondering Is it possible to run PETSc on Window Intel Mkl
> platform? If the answer is yes, so how and/or   any where can I
> addressed myself for to get help. Thanks and
> Kind regards
> Hung T. Nguyen
> Research in Numerical Analys
> Norway
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110324/fe95c13c/attachment.htm>
