[petsc-users] -pc_factor_shift_type command line
Mon Mar 21 05:25:30 CDT 2011
On Mon, Mar 21, 2011 at 5:15 AM, Umut Tabak <u.tabak at tudelft.nl> wrote:
> Dear all,
> What are the options for -pc_factor_shift_type?
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/PC/PCFactorSetShiftType.html
   Matt
> From the manual page, I understand I should use the -help option with the
> binary, but I guess the source code should include this function to get the
> help right? I am using a different laptop so that is the reason I did not
> have the chance to check that quickly. Is that the case, to get the help the
> function should be used in the source file? Or how can learn these options?
> Best regards,
> Umut
> If I have a thousand ideas and only one turns out to be good,
> I am satisfied.
> Alfred Nobel
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110321/efbb5cf4/attachment.htm>
