[petsc-users] Problem with Petcs link to window Intel MKl mkl_blas95.lib, mkl_lapack95.lib and mkl_blas_intelmpi.lib
Hung Thanh Nguyen hung.thanh.nguyen at petrell.no
Tue Mar 15 08:25:38 CDT 2011
Hi petcs-using
Thank for fast responding Grayver. I try:
./config/configure.py --with-cc='win32fe icc' --with-fc='win32fe ifort'  --with-cxx='win32fe icc'
and I got the following error message:
Could not found C-compilers
I try :
and got the error message:
C compiler you provided with --with-cc='win32fe icc' does not work, try -with-batch
I try again and got the new following error message:
./config/configure.py -with-batch --with-cc='win32fe icc' --with-fc='win32fe f95'  --with-cxx='win32fe icc'
UNABLE to execute Binaries for congig/configure.py
I Hope that you can help me to solve the problem. Thank a lot.
Hung T. Nguyen
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Alexander Grayver
Sent: 15. mars 2011 13:47
To: PETSc users list
Subject: Re: [petsc-users] Problem with Petcs link to window Intel MKl mkl_blas95.lib, mkl_lapack95.lib and mkl_blas_intelmpi.lib
I would suggest that you have to define the name of the compiler which will be used. In case of Intel compiler I guess it should be:
On 15.03.2011 13:33, Hung Thanh Nguyen wrote:
Dear PETSc use
I try to install PETSc on window Intel MKL and include mkl_blas95.lib, mkl_lapack95.lib and mkl_blacs_intelmpi.lib ( or mkl_mpich2.lib).
Intel MKL compiler 11.6-067. The following config-procedure
$ ./config/configure.py   / --with-petsc-arch=intel-32-static / --with-f-blas95-lapack-dir=/intel/Compiler/11.1/067/mkl/ia32/lib / --with-mpich2-dir=
I am also try:
$ ./config/configure.py   / --with-petsc-arch=intel-32-static / --with-f-blas-lapack-dir=/intel/Compiler/11.1/067/mkl/ia32/lib / --with-mpi-dir=
I got error message:
Could not locate a functional C compiler
What I am doing wrong?
Thanks
Hung T Nguyen
Physis and techonology Inst. University in Tromsø
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110315/97107eed/attachment-0001.htm>
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110315/97107eed/attachment-0001.obj>
