[petsc-users] Problem with Petcs link to window Intel MKl mkl_blas95.lib, mkl_lapack95.lib and mkl_blas_intelmpi.lib
Alexander Grayver
agrayver at gfz-potsdam.de
Tue Mar 15 07:47:26 CDT 2011
I would suggest that you have to define the name of the compiler which
will be used. In case of Intel compiler I guess it should be:
--with-cc='win32fe icc' --with-fc='win32fe ifort' --with-cxx='win32fe icc'
On 15.03.2011 13:33, Hung Thanh Nguyen wrote:
> Dear PETSc use
> I try to install PETSc on window Intel MKL and include mkl_blas95.lib,
> mkl_lapack95.lib and mkl_blacs_intelmpi.lib ( or mkl_mpich2.lib).
> Intel MKL compiler 11.6-067. The following config-procedure
> /$ ./config/configure.py / --with-petsc-arch=intel-32-static /
> --with-f-blas95-lapack-dir=/intel/Compiler/11.1/067/mkl/ia32/lib /
> --with-mpich2-dir=/
> /=/intel/Compiler/11.1/067/mkl/ia32/lib/
> I am also try:
> --with-f-blas-lapack-dir=/intel/Compiler/11.1/067/mkl/ia32/lib /
> --with-mpi-dir=/
> *I got error message:*
> *Could not locate a functional C compiler *
> What I am doing wrong?
> Thanks
> Hung T Nguyen
> Physis and techonology Inst. University in Tromsø
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110315/f5b9e021/attachment.htm>
