[petsc-users] PCASMSetLocalSubdomains Question
Gaetan Kenway kenway at utias.utoronto.ca
Thu Mar 10 14:44:32 CST 2011
Hello
I am trying to setup a Additive Schwartz Preconditioner using multiple
blocks on each processor. My code is a 3D Multiblock CFD code and what I am
trying to do is to put each CFD block into its own subdomain, even if there
are more than 1 block on each processor. The PETSc help on this function
wasn't helpful nor was the one example.
I don't understand the difference between "is" and "is_local". Are you
supposed to set 1 or both or neither?
As an example what I'm currently doing, for a given processor I want to
split into ndom subdomains I don the following
PetscFortranAddr,dimension(:),allocatable :: is_local
allocate(is_local(ndom))
do nn=1,ndom ! Loop over block on this processor
    ! create the index set for this domain -> Indicies contains the global
indices for the the current subdomain -> Code not shown
    call
ISCreateGeneral(PETSC_COMM_WORLD,nindices,indices,is_local(nn),PETScIerr)
asdf
 call PCASMSetLocalSubdomains(pc,ndom,PETSC_NULL_OBJECT,is_local,PETScIerr)
This dies with error code 85:  Argument is null that should not be
The traceback I get is:
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] PetscObjectReference line 112 src/sys/objects/inherit.c
[0]PETSC ERROR: [0] PCASMSetLocalSubdomains_ASM line 525
src/ksp/pc/impls/asm/asm.c
[0]PETSC ERROR: [0] PCASMSetLocalSubdomains line 699
I'm trying to use this with a block AIJ Matrix. Does the setlocalsubdomains
work with block AIJ Matrices?
Thank you,
Gaetan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110310/a9c0d6f9/attachment.htm>
