[petsc-users] MKL library - how to force static linking
Satish Balay
balay at mcs.anl.gov
Wed Mar 9 16:36:34 CST 2011
On Wed, 9 Mar 2011, Robert Ellis wrote:
> Hi Satish,
> I've looked at the Intel docs and find that to have ifort use static MKL libraries I need to add /Qopenmp-link:static to the ifort command. Given this information, is the correct form for the config script (options preceded by - and space separated)?
> --FOPTFLAGS='-Qopenmp-link:static -O3'
Sure this is fine. You might also want to add in similar COPTFLAGS.
> and the libraries I need are: mkl_intel_lp64.lib, mkl_intel_thread.lib, mkl_core.lib, libiomp5mt.lib
> Is the correct form full-pathname-comma-separated?
> --with-blas-lapack-lib='/cygdrive/
> c/mkl/lib/intel64/mkl_intel_lp64.lib,/cygdrive/c/mkl/lib/intel64/mkl_intel_thread.lib,/cygdrive/c/mkl/lib/intel64/mkl_core.lib,/cygdrive/c/Program\ Files\ \(x86\)/Intel/ComposerXE-2011/compiler/lib/intel64/libiomp5mt.lib'
> I've tried various things but keep getting the error
> Invalid library: /cygdrive/c/mkl/lib/intel64/mkl_intel_lp64.lib,/cygdrive/c/mkl/lib/intel64/mkl_intel_thread.lib,/cygdrive/c/mkl/lib/intel64/mkl_core.lib,/cygdrive/c/Program\ Files\ \(x86\)/Intel/ComposerXE-2011/compiler/lib/intel64/libiomp5mt.lib for key with-blas-lapack-lib
For one the above should be a python list. And then -
configure has trouble with 'spaces' and 'braces' in these paths. Suggest doing:
- create a dir for the required libs - say
mkdir $(HOME)/MKL
copy the required files over here.
and now use:
--with-blas-lapack-lib=[$(HOME)/MKL/mkl_intel_lp64.lib,$(HOME)/MKL/mkl_intel_thread.lib,...]
Also the following might work - but I'm not sure..
--with-blas-lapack-lib="-L$(HOME)/MKL mkl_intel_lp64.lib mkl_intel_thread.lib ..."
If you have issues - send configure.log to petsc-maint
Satish
> The following link is helpful for those of us trying to link MKL statically http://software.intel.com/en-us/forums/showthread.php?t=64254
> Cheers,
> Rob
> -----Original Message-----
> From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Satish Balay
> Sent: Wednesday, March 09, 2011 10:31 AM
> To: PETSc users list
> Subject: Re: [petsc-users] MKL library - how to force static linking
> If you know the correct MLK library list for static linking- you can
> try specifying with --with-blas-lapack-lib option
> Satish
> > Hi PETSc Experts,
> > Environment: Win, Cygwin, ifort, MKL to produce Win exes.
> > I'm using the MKL blas-lapack with the configure parameter --with-blas-lapack-dir=/cygdrive/c/mkl/lib/intel64. The resultant executable requires MKL dlls to run, specifically fmpich2.dll, libiomp5md.dll, mkl_core.dll, mkl_intel_thread.dll, mpich2mpi.dll. Can I force a static PETSc build using the MKL libraries? (BTW, using --download-f-blas-lapack produces a statically linked exe.)
> > Thanks for any help,
> > Cheers,
> > Rob
