[petsc-users] loosing preallocation information
Alexander Grayver
agrayver at gfz-potsdam.de
Mon Mar 7 08:41:16 CST 2011
It works! Great, Matt.
I guess there is no other way to know all these small issues but to get
all possible errors? :)
Jed, Matt, thank you a lot!
On 07.03.2011 15:35, Matthew Knepley wrote:
> On Mon, Mar 7, 2011 at 8:04 AM, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
> Jed, but why do I get in line 3003 in src/mat/impls/aij/seq/aij.c
> at all? As far as understand, if I don't pass nnz (NULL in C/C++
> or PETSC_NULL in fortran) I have to avoid this loop in aij.c code.
> This is the problem. Fortran does not allow this kind of flexible
> checking, so there are different kinds of "NULL"s. You
> need to pass PETSC_NULL_INTEGER for nnz.
> Matt
> I don't have much experience with valgrind. Could you provide me
> with right parameters to run my code under valgrind?
> Thanks a lot for your help.
> On 07.03.2011 14:59, Jed Brown wrote:
>> Looks like a memory error. Best bet is to run in Valgrind.
>>> On Mar 7, 2011 5:52 AM, "Alexander Grayver"
>>> Hi Jed,
>>> It's getting even stranger.
>>> When I run this code under linux I've got error:
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Argument out of range!
>>> [0]PETSC ERROR: nnz cannot be greater than row length: local row
>>> 98 value 1455203639 rowlength 343!
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20
>>> 14:26:37 CST 2010
>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR:
>>> /home/mt/agrayver/mt-soft/multiem/INV3D/_tiger/em_model on a
>>> openmpi-i named glic by agrayver Mon Mar 7 14:49:43 2011
>>> [0]PETSC ERROR: Libraries linked from
>>> /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-3.1-p7/openmpi-intel-complex-debug/lib
>>> [0]PETSC ERROR: Configure run at Fri Mar 4 12:43:58 2011
>>> [0]PETSC ERROR: Configure options
>>> --with-petsc-arch=openmpi-intel-complex-debug
>>> --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2
>>> --with-scalar-type=complex
>>> --with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t --with-precision=double
>>> --with-x=0
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: MatSeqAIJSetPreallocation_SeqAIJ() line 3003 in
>>> [0]PETSC ERROR: MatCreateSeqAIJ() line 2906 in
>>> Then I traced it under debugger both on Windows and Linux and
>>> realized that it doesn't crash under Windows only by luck.
>>> The call stack if the folowing:
>>> [C] MatSeqAIJSetPreallocation_SeqAIJ, FP=7fffb4513880
>>> [C] MatCreateSeqAIJ, FP=7fffb4513900
>>> [C] matcreateseqaij_, FP=7fffb4513960
>>> [F90] MODELING_MOD`modeling, FP=7fffb4517740
>>> As far as I understand after debugging the problem is that nnz
>>> in MatSeqAIJSetPreallocation isn't 0 and I go through this code:
>>> if (nnz) {
>>> for (i=0; i<B->rmap->n; i++) {
>>> if (nnz[i] < 0) SETERRQ2(PETSC_ERR_ARG_OUTOFRANGE,"nnz
>>> cannot be less than 0: local row %d value %d",i,nnz[i]);
>>> if (nnz[i] > B->cmap->n)
>>> SETERRQ3(PETSC_ERR_ARG_OUTOFRANGE,"nnz cannot be greater than
>>> row length: local row %d value %d rowlength
>>> %d",i,nnz[i],B->cmap->n);
>>> But why is nnz nonzero? I passed PETSC_NULL. It seems like
>>> macros CHKFORTRANNULLINTEGER in matcreateseqaij_ should set it
>>> to zero, but it doesn't.
>>> Thanks.
>>> On 06.03.2011 16:49, Jed Brown wrote:
>>> > On Sun, Mar 6, 2011 at 07:39, Alexander Grayver
>>> >> Hello,
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110307/63a2174b/attachment.htm>
