[petsc-users] loosing preallocation information
Mon Mar 7 08:35:28 CST 2011
On Mon, Mar 7, 2011 at 8:04 AM, Alexander Grayver
<agrayver at gfz-potsdam.de>wrote:
>  Jed, but why do I get in line 3003 in src/mat/impls/aij/seq/aij.c at all?
> As far as understand, if I don't pass nnz (NULL in C/C++ or PETSC_NULL in
> fortran) I have to avoid this loop in aij.c code.
This is the problem. Fortran does not allow this kind of flexible checking,
so there are different kinds of "NULL"s. You
need to pass PETSC_NULL_INTEGER for nnz.
   Matt
> I don't have much experience with valgrind. Could you provide me with right
> parameters to run my code under valgrind?
> Thanks a lot for your help.
> On 07.03.2011 14:59, Jed Brown wrote:
> Looks like a memory error. Best bet is to run in Valgrind.
> On Mar 7, 2011 5:52 AM, "Alexander Grayver" <agrayver at gfz-potsdam.de>
> wrote:
>  Hi Jed,
> It's getting even stranger.
> When I run this code under linux I've got error:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Argument out of range!
> [0]PETSC ERROR: nnz cannot be greater than row length: local row 98 value
> 1455203639 rowlength 343!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37
> CST 2010
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: /home/mt/agrayver/mt-soft/multiem/INV3D/_tiger/em_model on
> a openmpi-i named glic by agrayver Mon Mar  7 14:49:43 2011
> [0]PETSC ERROR: Libraries linked from
> /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-3.1-p7/openmpi-intel-complex-debug/lib
> [0]PETSC ERROR: Configure run at Fri Mar  4 12:43:58 2011
> [0]PETSC ERROR: Configure options
> --with-petsc-arch=openmpi-intel-complex-debug
> --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2 --with-scalar-type=complex
> --with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t
> --with-precision=double --with-x=0
> [0]PETSC ERROR:
> [0]PETSC ERROR: MatSeqAIJSetPreallocation_SeqAIJ() line 3003 in
> [0]PETSC ERROR: MatCreateSeqAIJ() line 2906 in src/mat/impls/aij/seq/aij.c
> Then I traced it under debugger both on Windows and Linux and realized that
> it doesn't crash under Windows only by luck.
> The call stack if the folowing:
> [C] MatSeqAIJSetPreallocation_SeqAIJ, FP=7fffb4513880
> [C] MatCreateSeqAIJ,     FP=7fffb4513900
> [C] matcreateseqaij_,    FP=7fffb4513960
> [F90] MODELING_MOD`modeling, FP=7fffb4517740
> As far as I understand after debugging the problem is that nnz in
> MatSeqAIJSetPreallocation isn't 0 and I go through this code:
>    if (nnz) {
>      for (i=0; i<B->rmap->n; i++) {
>        if (nnz[i] < 0) SETERRQ2(PETSC_ERR_ARG_OUTOFRANGE,"nnz cannot be
> less than 0: local row %d value %d",i,nnz[i]);
>        if (nnz[i] > B->cmap->n) SETERRQ3(PETSC_ERR_ARG_OUTOFRANGE,"nnz
> cannot be greater than row length: local row %d value %d rowlength
> %d",i,nnz[i],B->cmap->n);
> But why is nnz nonzero? I passed PETSC_NULL. It seems like macros
> CHKFORTRANNULLINTEGER  in matcreateseqaij_ should set it to zero, but it
> doesn't.
> Thanks.
> On 06.03.2011 16:49, Jed Brown wrote:
> > On Sun, Mar 6, 2011 at 07:39, Alexander Grayver <agrayver at gfz-potsdam.de>
> wrote:
> >> Hello,
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110307/6903096c/attachment-0001.htm>
