[petsc-users] Calling convention from windows VC++ and IFC
Satish Balay
balay at mcs.anl.gov
Thu Mar 3 09:26:34 CST 2011
perhaps you can remove '--CXX_CXXFLAGS=-Gz' and retry.
Satish
On Thu, 3 Mar 2011, Alexander Grayver wrote:
> I've sent them, thanks!
> I also must note that this is a problem for fortran examples only! Because
> when I've done "make test" after building the situation was:
> mt at agrayver /cygdrive/d/dev/petsc-3.1-p7
> $ make PETSC_DIR=/cygdrive/d/dev/petsc-3.1-p7 PETSC_ARCH=cygwin-cxx-debug test
> Running test examples to verify correct installation
> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI
> process
> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2 MPI
> processes
> --------------Error detected during compile or link!-----------------------
> See http://www.mcs.anl.gov/petsc/petsc-2/documentation/troubleshooting.html
> /cygdrive/d/dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -c -MT -Z7 -fpp
> -I/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/include
> -I/cygdrive/d/dev/petsc-3.1-p7/include -I/cygdrive/d/Dev/HPC_2008_SDK/Include
> -I/cygdrive/d/Dev/HPC_2008_SDK/Include -o ex5f.o ex5f.F
> /cygdrive/d/dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -MT -Z7 -fpp -o ex5f
> ex5f.o -L/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/lib
> -L/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/lib -lpetsc
> -L/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/lib -lflapack -lfblas
> /cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpi.lib
> /cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpifec.lib Gdi32.lib User32.lib
> Advapi32.lib Kernel32.lib Ws2_32.lib
> libpetsc.lib(fuser.o) : error LNK2019: unresolved external symbol
> __imp_GetUserNameA referenced in function "int __cdecl PetscGetUserName(char *
> const,unsigned__int64)" (?PetscGetUserName@@YAHQEAD_K at Z)
> libpetsc.lib(win32draw.o) : error LNK2019: unresolved external symbol
> __imp_ReleaseDC referenced in function "int __cdecl
> PetscDrawSetDoubleBuffer_Win32(struct_p_PetscDraw *)"
> (?PetscDrawSetDoubleBuffer_Win32@@YAHPEAU_p_PetscDraw@@@Z)
> __imp_BitBlt referenced in function "int __cdecl
> PetscDrawSetDoubleBuffer_Win32(struct _p_PetscDraw *)"
> __imp_ExtFloodFill referenced in function "int __cdecl
> __imp_SelectObject referenced in function "int __cdecl
> __imp_CreateCompatibleBitmap referenced in function "int __cdecl
> __imp_CreateCompatibleDC referenced in function "int __cdecl
> __imp_GetDC referenced in function "int __cdecl
> __imp_UpdateWindow referenced in function "int __cdecl
> PetscDrawRectangle_Win32(struct _p_PetscDraw
> *,double,double,double,double,int,int,int,int)"
> (?PetscDrawRectangle_Win32@@YAHPEAU_p_PetscDraw@@NNNNHHHH at Z)
> On 03.03.2011 14:49, Satish Balay wrote:
> > can you send the corresponding configure.log and make.log to
> > petsc-maint at mcs.anl.gov?
> > Satish
> > > Hello,
> > > I built PETSc-3.1 using VC++ 2008 and IFC 10.1 with the following
> > > configuration line:
> > > ./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe ifort'
> > > --with-cxx='win32fe cl' --download-f-blas-lapack=1
> > > --with-precision=double
> > > --with-scalar-type=complex --with-clanguage=cxx
> > > --with-mpi-include="/cygdrive/d/Dev/HPC_2008_SDK/Include"
> > > --with-mpi-lib=["/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpi.lib","/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpifec.lib"]
> > > --useThreads=0 --with-shared=0
> > > Note there is C++ as main language.
> > > Now, when I'm trying to build examples I always get similar errors:
> > > Error 2 error LNK2019: unresolved external symbol ZGESVD referenced
> > > in
> > > function "int __cdecl KSPComputeExtremeSingularValues_GMRES(struct _p_KSP
> > > *,double *,double *)"
> > > (?KSPComputeExtremeSingularValues_GMRES@@YAHPEAU_p_KSP@@PEAN1 at Z)
> > > libpetsc.lib
> > > Error 3 error LNK2019: unresolved external symbol ZGEEV referenced
> > > in
> > > function "int __cdecl KSPComputeEigenvalues_GMRES(struct _p_KSP
> > > *,int,double
> > > *,double *,int *)"
> > > (?KSPComputeEigenvalues_GMRES@@YAHPEAU_p_KSP@@HPEAN1PEAH at Z)
> > > libpetsc.lib
> > > Error 4 error LNK2001: unresolved external symbol ZGEEV
> > > libpetsc.lib
> > > Error 5 error LNK2019: unresolved external symbol DZNRM2 referenced
> > > in
> > > function "int __cdecl VecNorm_MPI(struct _p_Vec *,enum NormType,double *)"
> > > (?VecNorm_MPI@@YAHPEAU_p_Vec@@W4NormType@@PEAN at Z) libpetsc.lib
> > > Error 6 error LNK2001: unresolved external symbol DZNRM2
> > > libpetsc.lib
> > > Error 7 error LNK2019: unresolved external symbol DZASUM referenced
> > > in
> > > function "int __cdecl VecNorm_Seq(struct _p_Vec *,enum NormType,double *)"
> > > (?VecNorm_Seq@@YAHPEAU_p_Vec@@W4NormType@@PEAN at Z) libpetsc.lib
> > > It look like calling conventions are in disagreement. Any ideas? May be I
> > > should specify conventions myself in configuration line? If so, how to do
> > > that?
