[petsc-users] Calling convention from windows VC++ and IFC
Alexander Grayver
agrayver at gfz-potsdam.de
Thu Mar 3 08:46:50 CST 2011
I've sent them, thanks!
I also must note that this is a problem for fortran examples only!
Because when I've done "make test" after building the situation was:
mt at agrayver /cygdrive/d/dev/petsc-3.1-p7
$ make PETSC_DIR=/cygdrive/d/dev/petsc-3.1-p7
PETSC_ARCH=cygwin-cxx-debug test
Running test examples to verify correct installation
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
MPI process
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2
MPI processes
--------------Error detected during compile or link!-----------------------
See http://www.mcs.anl.gov/petsc/petsc-2/documentation/troubleshooting.html
/cygdrive/d/dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -c -MT -Z7 -fpp
-I/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/include
-I/cygdrive/d/dev/petsc-3.1-p7/include
-I/cygdrive/d/Dev/HPC_2008_SDK/Include
-I/cygdrive/d/Dev/HPC_2008_SDK/Include -o ex5f.o ex5f.F
/cygdrive/d/dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -MT -Z7 -fpp -o
ex5f ex5f.o -L/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/lib
-L/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/lib -lpetsc
-L/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/lib -lflapack -lfblas
/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpi.lib
/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpifec.lib Gdi32.lib User32.lib
Advapi32.lib Kernel32.lib Ws2_32.lib
libpetsc.lib(fuser.o) : error LNK2019: unresolved external symbol
__imp_GetUserNameA referenced in function "int __cdecl
PetscGetUserName(char * const,unsigned__int64)"
(?PetscGetUserName@@YAHQEAD_K at Z)
libpetsc.lib(win32draw.o) : error LNK2019: unresolved external symbol
__imp_ReleaseDC referenced in function "int __cdecl
PetscDrawSetDoubleBuffer_Win32(struct_p_PetscDraw *)"
(?PetscDrawSetDoubleBuffer_Win32@@YAHPEAU_p_PetscDraw@@@Z)
__imp_BitBlt referenced in function "int __cdecl
PetscDrawSetDoubleBuffer_Win32(struct _p_PetscDraw *)"
__imp_ExtFloodFill referenced in function "int __cdecl
__imp_SelectObject referenced in function "int __cdecl
__imp_CreateCompatibleBitmap referenced in function "int __cdecl
__imp_CreateCompatibleDC referenced in function "int __cdecl
__imp_GetDC referenced in function "int __cdecl
__imp_UpdateWindow referenced in function "int __cdecl
PetscDrawRectangle_Win32(struct _p_PetscDraw
*,double,double,double,double,int,int,int,int)"
(?PetscDrawRectangle_Win32@@YAHPEAU_p_PetscDraw@@NNNNHHHH at Z)
On 03.03.2011 14:49, Satish Balay wrote:
> can you send the corresponding configure.log and make.log to petsc-maint at mcs.anl.gov?
> Satish
> On Thu, 3 Mar 2011, Alexander Grayver wrote:
>> Hello,
>> I built PETSc-3.1 using VC++ 2008 and IFC 10.1 with the following
>> configuration line:
>> ./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe ifort'
>> --with-cxx='win32fe cl' --download-f-blas-lapack=1 --with-precision=double
>> --with-scalar-type=complex --with-clanguage=cxx
>> --with-mpi-include="/cygdrive/d/Dev/HPC_2008_SDK/Include"
>> --with-mpi-lib=["/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpi.lib","/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpifec.lib"]
>> --useThreads=0 --with-shared=0
>> Note there is C++ as main language.
>> Now, when I'm trying to build examples I always get similar errors:
>> Error 2 error LNK2019: unresolved external symbol ZGESVD referenced in
>> function "int __cdecl KSPComputeExtremeSingularValues_GMRES(struct _p_KSP
>> *,double *,double *)"
>> (?KSPComputeExtremeSingularValues_GMRES@@YAHPEAU_p_KSP@@PEAN1 at Z)
>> libpetsc.lib
>> Error 3 error LNK2019: unresolved external symbol ZGEEV referenced in
>> function "int __cdecl KSPComputeEigenvalues_GMRES(struct _p_KSP *,int,double
>> *,double *,int *)" (?KSPComputeEigenvalues_GMRES@@YAHPEAU_p_KSP@@HPEAN1PEAH at Z)
>> libpetsc.lib
>> Error 4 error LNK2001: unresolved external symbol ZGEEV libpetsc.lib
>> Error 5 error LNK2019: unresolved external symbol DZNRM2 referenced in
>> function "int __cdecl VecNorm_MPI(struct _p_Vec *,enum NormType,double *)"
>> (?VecNorm_MPI@@YAHPEAU_p_Vec@@W4NormType@@PEAN at Z) libpetsc.lib
>> Error 6 error LNK2001: unresolved external symbol DZNRM2
>> libpetsc.lib
>> Error 7 error LNK2019: unresolved external symbol DZASUM referenced in
>> function "int __cdecl VecNorm_Seq(struct _p_Vec *,enum NormType,double *)"
>> (?VecNorm_Seq@@YAHPEAU_p_Vec@@W4NormType@@PEAN at Z) libpetsc.lib
>> It look like calling conventions are in disagreement. Any ideas? May be I
>> should specify conventions myself in configuration line? If so, how to do
>> that?
