[petsc-users] Calling convention from windows VC++ and IFC
Alexander Grayver agrayver at gfz-potsdam.de
Thu Mar 3 05:51:32 CST 2011
Hello,
I built PETSc-3.1 using VC++ 2008 and IFC 10.1 with the following
configuration line:
./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe ifort'
--with-cxx='win32fe cl'  --download-f-blas-lapack=1
--with-precision=double --with-scalar-type=complex --with-clanguage=cxx
--with-mpi-include="/cygdrive/d/Dev/HPC_2008_SDK/Include"
--with-mpi-lib=["/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpi.lib","/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpifec.lib"]
--useThreads=0 --with-shared=0
Note there is C++ as main language.
Now, when I'm trying to build examples I always get similar errors:
Error    2     error LNK2019: unresolved external symbol ZGESVD
referenced in function "int __cdecl
KSPComputeExtremeSingularValues_GMRES(struct _p_KSP *,double *,double
*)" (?KSPComputeExtremeSingularValues_GMRES@@YAHPEAU_p_KSP@@PEAN1 at Z)
libpetsc.lib
Error    3     error LNK2019: unresolved external symbol ZGEEV
referenced in function "int __cdecl KSPComputeEigenvalues_GMRES(struct
_p_KSP *,int,double *,double *,int *)"
(?KSPComputeEigenvalues_GMRES@@YAHPEAU_p_KSP@@HPEAN1PEAH at Z)    libpetsc.lib
Error    4     error LNK2001: unresolved external symbol ZGEEV
libpetsc.lib
Error    5     error LNK2019: unresolved external symbol DZNRM2
referenced in function "int __cdecl VecNorm_MPI(struct _p_Vec *,enum
NormType,double *)" (?VecNorm_MPI@@YAHPEAU_p_Vec@@W4NormType@@PEAN at Z)
libpetsc.lib
Error    6     error LNK2001: unresolved external symbol DZNRM2
libpetsc.lib
Error    7     error LNK2019: unresolved external symbol DZASUM
referenced in function "int __cdecl VecNorm_Seq(struct _p_Vec *,enum
NormType,double *)" (?VecNorm_Seq@@YAHPEAU_p_Vec@@W4NormType@@PEAN at Z)
libpetsc.lib
It look like calling conventions are in disagreement. Any ideas? May be
I should specify conventions myself in configuration line? If so, how to
do that?
