[petsc-users] Factor Matrix
Barry Smith
bsmith at mcs.anl.gov
Wed Mar 2 21:26:19 CST 2011
On Mar 2, 2011, at 6:52 PM, Joshua Booth wrote:
> In reply,
> Yes , I meant with MatCopy or MatConvert.
> I need the values so I can store them in a larger matrix for latter use. It is in process of working on an experimental multilevel method.
Store the LU factors or C factors of a given matrix inside a larger matrix. Strange stuff. This is exactly the case where you should include src/mat/impls/sbaij/seq/sbaij.h
and access the data structure directly to do what you want with the values.
Barry
> Josh
> On Wed, Mar 2, 2011 at 7:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Mar 2, 2011, at 6:12 PM, Joshua Booth wrote:
> > In petsc, I am able to get a cholesky factor matrix from MatCholeskyFactor, but I am unable to copy
> Do you mean MatCopy() ?
> > or get values from it after.
> What do you want to use the values for? Normally they are only used in triangular solvers with MatSolve().
> The data is stored in a matrix specific format. You would have to include the private include files and access the data directly if you need it. src/mat/impls/sbaij/seq/sbaij.h
> Barry
> > Why is this? Is there a work around?
> > Joshua Booth
