[petsc-users] ILU preconditioner
Fri Jun 3 09:07:34 CDT 2011
   Unfortunately PETSc is restricted to working with only real or complex objects at one time and one cannot mix some real and some complex.
   Barry
On Jun 3, 2011, at 9:03 AM, Danesh Daroui wrote:
> Hi,
> In this case, can I create a preconditioner in double precision format
> and apply it to the system while I am using PETSc to solve a system of
> complex numbers? The reason is that I am solving equations in several
> iterations and I want to create an ILU-based preconditioner only on real
> part of my coefficient matrix because it is unchanged and I can create
> and store is once. The imaginary parts will change but they do not have
> big effect.
> Regards,
> D.
> On Tue, 2011-05-31 at 15:13 +0200, Jed Brown wrote:
>> On Tue, May 31, 2011 at 08:02, Danesh Daroui <danesh.daroui at ltu.se>
>> wrote:
>>        I have a complex system of equations and I use PETSc to solve
>>        the
>>        system. I also use MKL to create the preconditioner using ILU.
>>        The ILU
>>        preconditioner is created only on the real part of the
>>        coefficient
>>        matrix and is stored in CSR format with the data type of
>>        double
>>        precision. I wanted to ask if it is possible to use this
>>        preconditioner
>>        and pass it to PETSc in CSR format? Can it be used with PETSc
>>        complex
>>        solver although the preconditioner is in double precision
>>        format?
>> You can create a PCShell() that manages the factorization using MKL
>> and applies the preconditioner stored in whatever format MKL likes.
>> PETSc would not know that it is ILU or otherwise. It sounds like that
>> would do what you want.
