[petsc-users] A question on "memory access out of range" in mpi running
Alan Wei
zhenglun.wei at gmail.com
Wed Jun 1 11:47:38 CDT 2011
Hi guys,
I hope you're having a nice day.
I was trying to run ex29.c in src/ksp/ksp/example/tutorial. It is normal
to go through without MPI. However, with the same grid size, if I run it
with 4 processes with MPI, a error message of "Caught signal number 11 SEGV:
Segmentation Violation, probably memory access out of range" will show up.
Did anyone have this kind of issue before. I guess this is probably caused
by the way I launched the 'mpiexec'. Any idea on it? The full error message
is attached.
Thanks in advance.
best,
Alan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110601/dc9da8b9/attachment.htm>
[1]PETSC ERROR: ------------------------------------------------------------------------
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[2]PETSC ERROR: ------------------------------------------------------------------------
[2]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[2]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[2]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[2]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[1]PETSC ERROR: likely location of problem given in stack below
[1]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[1]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[1]PETSC ERROR: INSTEAD the line number of the start of the function
[1]PETSC ERROR: is given.
[1]PETSC ERROR: [1] VecView_VTK line 230 src/ksp/ksp/examples/tutorials/ex29.c
[1]PETSC ERROR: --------------------- Error Message ------------------------------------
[1]PETSC ERROR: Signal received!
[1]PETSC ERROR: Petsc Development HG revision: f4c0045a3598c355546a497a4596696abe625181 HG Date: Thu May 26 14:04:32 2011 -0500
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR: ------------------------------------------------------------------[2]PETSC ERROR: likely location of problem given in stack below
[2]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[2]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[2]PETSC ERROR: INSTEAD the line number of the start of the function
[2]PETSC ERROR: is given.
[2]PETSC ERROR: [2] VecView_VTK line 230 src/ksp/ksp/examples/tutorials/ex29.c
[2]PETSC ERROR: --------------------- Error Message ------------------------------------
[2]PETSC ERROR: Signal received!
[2]PETSC ERROR: Petsc Development HG revision: f4c0045a3598c355546a497a4596696abe625181 HG Date: Thu May 26 14:04:32 2011 -0500
[2]PETSC ERROR: See docs/changes/index.html for recent updates.
[2]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[2]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR: ./ex29 on a arch-linu named l2118a-linux.soecs.ku.edu by zlwei Tue May 31 15:16:53 2011
[1]PETSC ERROR: Libraries linked from /home/zlwei/soft/mercurial/petsc-dev/arch-linux2-c-debug/lib
[1]PETSC ERROR: Configure run at Thu May 26 15:32:02 2011
[1]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran --download-f-blas-lapack=1 --download-mpich=1
[1]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
[cli_1]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1
[2]PETSC ERROR: ./ex29 on a arch-linu named l2118a-linux.soecs.ku.edu by zlwei Tue May 31 15:16:53 2011
[2]PETSC ERROR: Libraries linked from /home/zlwei/soft/mercurial/petsc-dev/arch-linux2-c-debug/lib
[2]PETSC ERROR: Configure run at Thu May 26 15:32:02 2011
[2]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran --download-f-blas-lapack=1 --download-mpich=1
[2]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 2
[cli_2]: aborting job:
[3]PETSC ERROR: ------------------------------------------------------------------------
[3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[3]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[3]PETSC ERROR: likely location of problem given in stack below
[3]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[3]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[3]PETSC ERROR: INSTEAD the line number of the start of the function
[3]PETSC ERROR: is given.
[3]PETSC ERROR: [3] VecView_VTK line 230 src/ksp/ksp/examples/tutorials/ex29.c
[3]PETSC ERROR: --------------------- Error Message ------------------------------------
[3]PETSC ERROR: Signal received!
[3]PETSC ERROR: Petsc Development HG revision: f4c0045a3598c355546a497a4596696abe625181 HG Date: Thu May 26 14:04:32 2011 -0500
[3]PETSC ERROR: See docs/changes/index.html for recent updates.
[3]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[3]PETSC ERROR: See docs/index.html for manual pages.
[3]PETSC ERROR: ./ex29 on a arch-linu named l2118a-linux.soecs.ku.edu by zlwei Tue May 31 15:16:53 2011
[3]PETSC ERROR: Libraries linked from /home/zlwei/soft/mercurial/petsc-dev/arch-linux2-c-debug/lib
[3]PETSC ERROR: Configure run at Thu May 26 15:32:02 2011
[3]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran --download-f-blas-lapack=1 --download-mpich=1
[3]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 3
[cli_3]: aborting job:
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] VecView_VTK line 230 src/ksp/ksp/examples/tutorials/ex29.c
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR: Petsc Development HG revision: f4c0045a3598c355546a497a4596696abe625181 HG Date: Thu May 26 14:04:32 2011 -0500
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: ./ex29 on a arch-linu named l2118a-linux.soecs.ku.edu by zlwei Tue May 31 15:16:53 2011
[0]PETSC ERROR: Libraries linked from /home/zlwei/soft/mercurial/petsc-dev/arch-linux2-c-debug/lib
[0]PETSC ERROR: Configure run at Thu May 26 15:32:02 2011
[0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran --download-f-blas-lapack=1 --download-mpich=1
[0]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[cli_0]: aborting job:
