[petsc-users] Grid Partitioning with ParMetis
Fri Jul 29 16:09:21 CDT 2011
On Fri, Jul 29, 2011 at 7:52 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
> Matt,
> Is ParMetis implementation in PETSc only done via
> $PETSC_DIR/src/mat/partition/impls/pmetis/pmetis.c ? I am wondering if PETSc
> has interface to ParMETIS_V3_RefineKway function as noted in ParMetis
> manual?
If you want to Mat, then pmetis.c is it. There is stuff for more general
meshes, but it is experimental. There is a paper about it
  http://arxiv.org/abs/0908.4427
which will give you an idea what it does.
     Matt
> Thanks,
> Mohammad
> On Thu, Jul 28, 2011 at 10:11 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>> I see. Thanks for the help Matt
>> On Thu, Jul 28, 2011 at 10:01 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Fri, Jul 29, 2011 at 4:52 AM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>>>> Thank you Matt. Indeed I have looked into p4est and also Dendro. p4est
>>>> uses parallel octrees/quadtrees but for what I intend to do I only need to
>>>> distribute a single tree that is created in serial among processors.
>>>> I definitely like to have the tree data-structure in parallel but that would
>>>> be another project. I also looked into Dendro and they kind of follow the
>>>> same strategy. i.e every single processor has a local copy of the whole
>>>> tree. What they do differently, however, is they somehow manage to use DA
>>>> instead of a general unstructured numbering which is quite interesting but I
>>>> still don't know how they do it. Unfortunately, they do not handle (as far
>>>> as I understood from their manual) non-graded trees which are the ones I
>>>> work with.
>>>> So, all I need to do is to somehow distribute my grid among processors
>>>> and since each one has a local copy of data-structure I could get around the
>>>> problem. Just anotehr question. If the partitioning is not unique, do you at
>>>> least get a better numbering than the tree you start with?
>>> You should, which is why I suggested that you are not giving the input
>>> you think you are.
>>>    Matt
>>>> Mohammad
>>>> On Thu, Jul 28, 2011 at 9:25 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Fri, Jul 29, 2011 at 3:49 AM, Mohammad Mirzadeh <mirzadeh at gmail.com
>>>>> > wrote:
>>>>>> Hi all,
>>>>>> I am trying to write a code to do parallel computation on quadtree
>>>>>> adaptive grids and to do so , I need to distribute the grid in parallel. I
>>>>>> have selected a general unstructured framework for telling PETSc about my
>>>>>> node numbering. An example of such grid is schematically shown below.
>>>>> 0) If you are doing this, I think you should at least look at the p4est
>>>>> package before proceeding.
>>>>>> 1                16              7                             3
>>>>>> |14             | 15           | 17                           |
>>>>>> | 4             | 12            | 6                            |8
>>>>>> | 9              | 11           |  13                         |
>>>>>> | 0              | 10           |5                             | 2
>>>>>> To distribute this in parallel I am using the ParMetis interface via MatPartitioning object and I follow(more or less) the example in $PETSC_DIR/src/dm/ao/examples/tutorials/ex2.c; To make the initial distribution, I choose nodal based partitioning by creating the adjacency matrix, for which I create ia and ja arrays accordingly. once the grid is processed and the new orderings are generated, I follow all required steps to generate the AO needed to map between PETSc ordering and the new global numbering and this is the result:
>>>>>> Number of elements in ordering 18
>>>>>> PETSc->App  App->PETSc
>>>>>>   0    9                  0    1
>>>>>>   1    0                  1    3
>>>>>>   2   10                 2    4
>>>>>>   3    1                  3    7
>>>>>>   4    2                  4   12
>>>>>>   5   11                 5   14
>>>>>>   6   12                 6   15
>>>>>>   7    3                  7   16
>>>>>>   8   13                 8   17
>>>>>>   9   14                 9    0
>>>>>>  10   15               10    2
>>>>>>  11   16               11    5
>>>>>>  12    4                12    6
>>>>>>  13   17               13    8
>>>>>>  14    5                14    9
>>>>>>  15    6                15   10
>>>>>>  16    7                16   11
>>>>>>  17    8                17   13
>>>>>> Now I have two questions/concerns:
>>>>>> 1) Do processors always have the nodes in contiguous chunks of PETSc
>>>>>> ordering? i.e 0-8 on rank 0 and 9-17 on rank 1 ? If so, this particular
>>>>>> ordering does not seem to be "good" for this grid since it seems to cross
>>>>>> too many edges in the graph (here 13 edges) and by just looking at the graph
>>>>>> I can(at least) think of a better distribution with only 6 edge cuts. (if
>>>>>> you are wondering how, having {0,9,4,14,1,10,11,12,15} on rank 0 and rest on
>>>>>> rank 1).
>>>>> Yes, the PETSc ordering is always contiguous. Perhaps you are not
>>>>> providing the graph you think you are for partitioning.
>>>>>> 2) Isn't  it true that the final distribution should be independent of
>>>>>> initial grid numbering? When I try the same grid but with the following
>>>>>> (hand-generated) numbering:
>>>>>>  14               15             16                             17
>>>>>> |11             | 12           | 13                           |
>>>>>> | 7             | 8              | 9                            |10
>>>>>> | 4              | 5             |  6                           |
>>>>>> | 0              | 1             |2                             | 3
>>>>>> I get the following AO:
>>>>>>   0    9                   0    9
>>>>>>   1   10                  1   10
>>>>>>   2   11                  2   11
>>>>>>   3   12                  3   12
>>>>>>   4   13                  4   13
>>>>>>   5   14                  5   14
>>>>>>   6   15                  6   15
>>>>>>   7   16                  7   16
>>>>>>   8   17                  8   17
>>>>>>   9    0                   9    0
>>>>>>  10    1                10    1
>>>>>>  11    2                11    2
>>>>>>  12    3                12    3
>>>>>>  13    4                13    4
>>>>>>  14    5                14    5
>>>>>>  15    6                15    6
>>>>>>  16    7                16    7
>>>>>>  17    8                17    8
>>>>>> which is simply the initial ordering with a change in the order in
>>>>>> which processors handle nodes.  Could it be that the partitioning is not
>>>>>> unique and each time the algorithm only tries to obtain the "best" possible
>>>>>> ordering depending on the initial distribution? If so, how should I know
>>>>>> what ordering to start with?
>>>>> Yes, ParMetis does not provide a unique "best" ordering, which is at
>>>>> least NP-complete if not worse.
>>>>>    Matt
>>>>>> I am really confused and would appreciate if someone could provide
>>>>>> some insights.
>>>>>> Thanks,
>>>>>> Mohammad
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110729/c1c27dc4/attachment.htm>
