[petsc-users] Preconditioned JFNK using SuperLU_dist for time dependent problems
Travis C. Fisher travis.fisher at nasa.gov
Fri Jul 29 12:52:54 CDT 2011
Barry,
I added the line,
call MatSetOption(pcmat,MAT_NEW_NONZERO_LOCATION_ERR,PETSC_TRUE,ierr),
after the call to matrix assembly and do not get an error associated
with the nonzero locations.
Here is the error running superlu_dist with one processor.
  0 SNES Function norm 9.448256037271e+02
        Nonzeros in L       21005940
        Nonzeros in U       21018240
        nonzeros in L+U     41958975
        nonzeros in LSUB    3914621
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC
ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] MatSolve_SuperLU_DIST line 117
/scratch/tfisher/petsc-dev/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
[0]PETSC ERROR: [0] MatSolve line 3039
/scratch/tfisher/petsc-dev/src/mat/interface/matrix.c
[0]PETSC ERROR: [0] PCApply_LU line 202
/scratch/tfisher/petsc-dev/src/ksp/pc/impls/factor/lu/lu.c
[0]PETSC ERROR: [0] PCApply line 373
/scratch/tfisher/petsc-dev/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: [0] KSPInitialResidual line 45
/scratch/tfisher/petsc-dev/src/ksp/ksp/interface/itres.c
[0]PETSC ERROR: [0] KSPSolve_LGMRES line 354
/scratch/tfisher/petsc-dev/src/ksp/ksp/impls/gmres/lgmres/lgmres.c
[0]PETSC ERROR: [0] KSPSolve line 330
/scratch/tfisher/petsc-dev/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: [0] SNES_KSPSolve line 3364
/scratch/tfisher/petsc-dev/src/snes/interface/snes.c
[0]PETSC ERROR: [0] SNESSolve_LS line 142
/scratch/tfisher/petsc-dev/src/snes/impls/ls/ls.c
[0]PETSC ERROR: [0] SNESSolve line 2617
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
77f4001db099d653cddbbaf61d75c0cf8cf833fd  HG Date: Fri Jul 29 13:41:12
2011 +0200
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./HFCFS on a arch-linu named larss-nad by tcfishe1 Fri
Jul 29 13:47:04 2011
[0]PETSC ERROR: Libraries linked from
/ump/fldmd/home/tcfishe1/gnucompiled/lib
[0]PETSC ERROR: Configure run at Fri Jul 29 11:37:36 2011
[0]PETSC ERROR: Configure options
--prefix=/ump/fldmd/home/tcfishe1/gnucompiled
--download-fblas-lapack=yes --download-superlu_dist=yes
--download-parmetis=yes --download-hypre=yes --download-mumps=yes
--download-blacs=yes --download-scalapack=yes
[0]PETSC ERROR:
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 59.
Travis
