[petsc-users] use Superlu as ilu preconditioner
Hong Zhang
hzhang at mcs.anl.gov
Fri Jul 29 09:42:39 CDT 2011
Ping :
Please send me your code. I do not understand why the system matrix is
overwritten
by factored matrix when superlu is used. We do not support in-place
factorization
for external packages. Something is incorrect here.
Hong
> I have found the problem. I don't know whether this is a bug.
> ierr = KSPSetOperators(_ksp, matrix->mat(), precond->mat(),
> this->same_preconditioner ?
> SAME_PRECONDITIONER : DIFFERENT_NONZERO_PATTERN);
> I used my system matrix as the precondition matrix, where matrix->mat() and
> precond->mat() are in deed the same matrix. I have left the
> KSPSetOperators(ksp) out before the KSPSolve(..) function, so
> KSPSetOperators() is called only once while the petsc_linear_solver object
> is initialized, which eliminated the petsc error ("object is in wrong
> state").
> Also when I used petsc default ilu preconditioner, everything is fine, also
> the solutions are correct. However, as long as I apply the superlu as my
> solver package, it overwrites the system matrix. I compared the system
> matrix before and after solve(). With petsc ilu, it remains identical, but
> with superlu ilu, the system matrix is changed to the preconditioner matrix
> itself. Now I simply duplicate the system matrix, and use this copy as
> precondition matrix. Everything works perfectly.
> The code I used is pretty standard, just as in ex2. It took me quite a while
> to realize the problem, because when the system matrix is replaced by the
> preconditioner matrix, you still get a "correct" solution, which is however
> incorrectly scaled.
> Ping
> Am 28.07.2011 18:21, schrieb Hong Zhang:
>> Ping :
>> I tested similar calling procedure using
>> petsc-dev/src/ksp/ksp/examples/tutorials/ex5.c
>> successfully.
>> Try following:
>> 1) switch to petsc-dev. See
>> http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html on how to
>> get it.
>> 2) send us a short and stand-alone code that reproduce the error. We
>> can investigate it.
>> Hong
>>> Dear Hong,
>>> thank you very much for your time. Can you tell me when should
>>> KSPSetFromOptions(ksp) be called?
>>> well, libMesh has a class called "petsc_linear_solver", in its original
>>> code
>>> KSPSetFromOptions(ksp) is called while the object is created. I couldn't
>>> get
>>> any output, when I run the program with the option
>>> -pc_type ilu -pc_factor_mat_solver_package superlu
>>> -mat_superlu_ilu_droptol 0.1 -ksp_view
>>> The actual solve() function of the "petsc_linear_solver" contains the
>>> similar code as in the ex2.c
>>> CHKERRABORT(libMesh::COMM_WORLD,ierr);
>>> // Set the tolerances for the iterative solver. Use the user-supplied
>>> // tolerance for the relative residual& leave the others at default
>>> values.
>>> ierr = KSPSetTolerances (_ksp, tol, PETSC_DEFAULT, PETSC_DEFAULT,
>>> max_its);
>>> ierr = KSPSetFromOptions (_ksp);<-------------- I added these two
>>> lines,
>>> CHKERRABORT(libMesh::COMM_WORLD,ierr);<-------------- then I got proper
>>> output.
>>> // Solve the linear system
>>> ierr = KSPSolve (_ksp, rhs->vec(), solution->vec());
>>> The problem is that I have to solve a multiple frequency system, and for
>>> each frequency I have several RHS. The same ksp context is used to solve
>>> the
>>> systems repeatedly. I always call KSPSetOperators() with the option
>>> DIFFERENT_NONZERO_PATTERN for the first RHS and SAME_PRECONDITIONER for
>>> the
>>> rest, since the system matrix remains the same. For the first frequency,
>>> everything is fine, both DIFFERENT_NONZERO_PATTERN and
>>> SAME_PRECONDITIONER
>>> options. I got following output from the -ksp_view.
>>> PC Object:
>>> type: ilu
>>> ILU: out-of-place factorization
>>> 0 levels of fill
>>> tolerance for zero pivot 1e-12
>>> using diagonal shift to prevent zero pivot
>>> matrix ordering: natural
>>> factor fill ratio given 0, needed 0
>>> Factored matrix follows:
>>> Matrix Object:
>>> type=seqaij, rows=2883, cols=2883
>>> package used to perform factorization: superlu<----------------
>>> superlu is properly set
>>> but when the second frequency comes up, KSPSetOperators() is called again
>>> with DIFFERENT_NONZERO_PATTERN option for the first RHS. the command line
>>> option doesn't seem to work anymore.
>>> PC Object:
>>> type: ilu
>>> 0 levels of fill
>>> factor fill ratio given 1, needed 1
>>> Matrix Object:
>>> package used to perform factorization: petsc<------------ not
>>> superlu anymore
>>> and then for the second RHS, when it calls KSPSetOperators(ksp) in the
>>> solve() routine, petsc throws the following error message.
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Object is in wrong state!
>>> [0]PETSC ERROR: Cannot change solver matrix package after PC has been
>>> setup
>>> or used!
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17 13:37:48
>>> CDT 2011
>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: ./PLTMainTest.opt on a linux-gnu named abe-vm by mubpr
>>> Wed
>>> Jul 27 19:41:22 2011
>>> [0]PETSC ERROR: Libraries linked from
>>> /home/mubpr/libs/petsc/linux-gnu-acml-shared-opt/lib
>>> [0]PETSC ERROR: Configure run at Tue Jul 26 22:09:39 2011
>>> [0]PETSC ERROR: Configure options
>>> --with-blas-lapack-lib=/home/mubpr/libs/acml/gfortran64_mp/lib/libacml_mp.so
>>> --with-blas-lapack-include=/home/mubpr/libs/acml/gfortran64_mp/include
>>> --with-scalar-type=complex --with-clanguage=c++
>>> --with-mpi-dir=/home/mubpr/libs/mpich2 --download-superlu=yes
>>> --with-superlu=1 --download-parmetis=yes --with-parmetis=1
>>> --download-superlu_dist=yes --with-superlu_dist=1 --download-mumps=yes
>>> --with-mumps=1 --download-blacs=yes --with-blacs=1
>>> --download-scalapack=yes
>>> --with-scalapack=1 --download-spooles=yes --with-spooles=1
>>> --download-umfpack=yes --with-umfpack=1 --with-debugging=no
>>> --with-shared=1
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: PCFactorSetMatSolverPackage_Factor() line 183 in
>>> src/ksp/pc/impls/factor/factimpl.c
>>> [0]PETSC ERROR: PCFactorSetMatSolverPackage() line 276 in
>>> src/ksp/pc/impls/factor/factor.c
>>> [0]PETSC ERROR: PCSetFromOptions_Factor() line 275 in
>>> [0]PETSC ERROR: PCSetFromOptions_ILU() line 112 in
>>> src/ksp/pc/impls/factor/ilu/ilu.c
>>> [0]PETSC ERROR: PCSetFromOptions() line 185 in
>>> src/ksp/pc/interface/pcset.c
>>> [0]PETSC ERROR: KSPSetFromOptions() line 323 in
>>> src/ksp/ksp/interface/itcl.c
>>> [0]PETSC ERROR: User provided function() line 696 in
>>> "unknowndirectory/"src/solvers/petsc_linear_solver.C
>>> Any idea what the problem may be? I would be very grateful, if you can
>>> give
>>> me any hint. thanks alot
>>> best regards
>>> Ping
>>> Am 27.07.2011 04:13, schrieb Hong Zhang:
>>>> Did you call KSPSetFromOptions(ksp)?
>>>> Run your code with '-options_table' to dump list of options inputted
>>>> or '-options_left' to dump list of unused options.
>>>> I tested with petsc-3.1/src/ksp/ksp/examples/tutorials/ex2.c:
>>>> ./ex2
>>>> SuperLU run parameters:
>>>> ILU_DropTol: 0.1
>>>> ILU_FillTol: 0.01
>>>> ILU_FillFactor: 10
>>>> ILU_DropRule: 9
>>>> ILU_Norm: 2
>>>> ILU_MILU: 2
>>>> Hong
>>>> On Tue, Jul 26, 2011 at 3:53 PM, Ping Rong<ping.rong at tuhh.de> wrote:
>>>>> Dear developers,
>>>>> I have compiled petsc-3.1-p8 for a while. Now I would like to use
>>>>> superlu
>>>>> as
>>>>> an ilu preconditioner, since it offers the drop tolerance option. I
>>>>> have
>>>>> read in a thread
>>>>> (https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2010-December/007439.html)
>>>>> that one can run the code with option
>>>>> to setup the ilu preconditioner. I also use the option "-help |grep
>>>>> superlu"
>>>>> to check the settings. However, no matter how I change the value of
>>>>> -mat_superlu_ilu_droptol, I always got the same result
>>>>> -mat_superlu_lwork<0>: size of work array in bytes used by
>>>>> factorization
>>>>> (None)
>>>>> -mat_superlu_ilu_droptol<0.0001>: ILU_DropTol (None)
>>>>> -mat_superlu_ilu_filltol<0.01>: ILU_FillTol (None)
>>>>> I dont know whether I understand it correctly. But it seems to me the
>>>>> value
>>>>> of the droptol has never been changed. In that maillist thread, it was
>>>>> also
>>>>> mentioned that the dev-version is recommended, because of some bugs in
>>>>> the
>>>>> superlu interface. I have then compiled the current dev-version. but
>>>>> the
>>>>> problem is my program is based on another library (libMesh) which uses
>>>>> petsc
>>>>> as a solver package. Since some of the interfaces have been changed in
>>>>> the
>>>>> dev-version, I would not be able to compile the libMesh with petsc
>>>>> anymore.
>>>>> Is there anyway I can correct the superlu interface in the 3.1-p8
>>>>> version
>>>>> directly? Any help will be appreciated!!
>>>>> Best regards
>>>>> Ping Rong, M.Sc.
>>>>> Hamburg University of Technology
>>>>> Institut of modelling and computation
>>>>> Denickestraße 17 (Room 3031)
>>>>> 21073 Hamburg
>>>>> Tel.: ++49 - (0)40 42878 2749
>>>>> Fax: ++49 - (0)40 42878 43533
>>>>> Email: ping.rong at tuhh.de
>>> Ping Rong, M.Sc.
>>> 21073 Hamburg
> Ping Rong, M.Sc.
> 21073 Hamburg
