[petsc-users] Preconditioned JFNK using SuperLU_dist for time	dependent problems
    Travis C. Fisher
    travis.fisher at nasa.gov
    Fri Jul 29 09:41:25 CDT 2011
I ran into the following problem when trying to use superlu_dist as a
preconditioner for matrix free SNES with GMRES in my high order Navier
Stokes solver:
I set the nonzero pattern of my preconditioner matrix at the begging of
a simulation (t=0). The overall stencil of the numerical method never
changes, so the nonzero pattern should never change. I use an implicit
Runge Kutta scheme to advance the solution in time. The preconditioning
matrix is the frozen jacobian at the start of a time step. The same
preconditioner is used for every stage of the RK scheme. After one time
step is complete, the preconditioner matrix is calculated for the new
time step.
The problem I am having with superlu_dist is that if I use
SAME_NONZERO_PATTERN, I get a segmentation violation. However, if I use
DIFFERENT_NONZERO_PATTERN, everything works fine. If I am conservative
about how I initialize the nonzero pattern and desire it to never to
change, why do I need to use DIFFERENT_NONZERO_PATTERN? Individual
components in the nonzero structure will be zero for some steps and not
others, but the overall nonzero structure is fixed. I don't get errors
when using Additive Schwarz with ILU, but I am wondering if convergence
problems occur because of how the nonzero patterns are handled. Any
ideas of what I am doing incorrectly? What is SAME_NONZERO_PATTERN
really telling the nonlinear solver over multiple calls? Most of the
examples only have one call to SNESSolve, so I feel that this is not
well covered elsewhere.
Thanks in advance.
Travis Fisher
