[petsc-users] Grid Partitioning with ParMetis
Fri Jul 29 00:01:04 CDT 2011
On Fri, Jul 29, 2011 at 4:52 AM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
> Thank you Matt. Indeed I have looked into p4est and also Dendro. p4est uses
> parallel octrees/quadtrees but for what I intend to do I only need to
> distribute a single tree that is created in serial among processors.
> I definitely like to have the tree data-structure in parallel but that would
> be another project. I also looked into Dendro and they kind of follow the
> same strategy. i.e every single processor has a local copy of the whole
> tree. What they do differently, however, is they somehow manage to use DA
> instead of a general unstructured numbering which is quite interesting but I
> still don't know how they do it. Unfortunately, they do not handle (as far
> as I understood from their manual) non-graded trees which are the ones I
> work with.
> So, all I need to do is to somehow distribute my grid among processors and
> since each one has a local copy of data-structure I could get around the
> problem. Just anotehr question. If the partitioning is not unique, do you at
> least get a better numbering than the tree you start with?
You should, which is why I suggested that you are not giving the input you
think you are.
   Matt
> Mohammad
> On Thu, Jul 28, 2011 at 9:25 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Fri, Jul 29, 2011 at 3:49 AM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>>> Hi all,
>>> I am trying to write a code to do parallel computation on quadtree
>>> adaptive grids and to do so , I need to distribute the grid in parallel. I
>>> have selected a general unstructured framework for telling PETSc about my
>>> node numbering. An example of such grid is schematically shown below.
>> 0) If you are doing this, I think you should at least look at the p4est
>> package before proceeding.
>>> 1                16              7                             3
>>> |14             | 15           | 17                           |
>>> | 4             | 12            | 6                            |8
>>> | 9              | 11           |  13                         |
>>> | 0              | 10           |5                             | 2
>>> To distribute this in parallel I am using the ParMetis interface via MatPartitioning object and I follow(more or less) the example in $PETSC_DIR/src/dm/ao/examples/tutorials/ex2.c; To make the initial distribution, I choose nodal based partitioning by creating the adjacency matrix, for which I create ia and ja arrays accordingly. once the grid is processed and the new orderings are generated, I follow all required steps to generate the AO needed to map between PETSc ordering and the new global numbering and this is the result:
>>> Number of elements in ordering 18
>>> PETSc->App  App->PETSc
>>>   0    9                  0    1
>>>   1    0                  1    3
>>>   2   10                 2    4
>>>   3    1                  3    7
>>>   4    2                  4   12
>>>   5   11                 5   14
>>>   6   12                 6   15
>>>   7    3                  7   16
>>>   8   13                 8   17
>>>   9   14                 9    0
>>>  10   15               10    2
>>>  11   16               11    5
>>>  12    4                12    6
>>>  13   17               13    8
>>>  14    5                14    9
>>>  15    6                15   10
>>>  16    7                16   11
>>>  17    8                17   13
>>> Now I have two questions/concerns:
>>> 1) Do processors always have the nodes in contiguous chunks of PETSc
>>> ordering? i.e 0-8 on rank 0 and 9-17 on rank 1 ? If so, this particular
>>> ordering does not seem to be "good" for this grid since it seems to cross
>>> too many edges in the graph (here 13 edges) and by just looking at the graph
>>> I can(at least) think of a better distribution with only 6 edge cuts. (if
>>> you are wondering how, having {0,9,4,14,1,10,11,12,15} on rank 0 and rest on
>>> rank 1).
>> Yes, the PETSc ordering is always contiguous. Perhaps you are not
>> providing the graph you think you are for partitioning.
>>> 2) Isn't  it true that the final distribution should be independent of
>>> initial grid numbering? When I try the same grid but with the following
>>> (hand-generated) numbering:
>>>  14               15             16                             17
>>> |11             | 12           | 13                           |
>>> | 7             | 8              | 9                            |10
>>> | 4              | 5             |  6                           |
>>> | 0              | 1             |2                             | 3
>>> I get the following AO:
>>>   0    9                   0    9
>>>   1   10                  1   10
>>>   2   11                  2   11
>>>   3   12                  3   12
>>>   4   13                  4   13
>>>   5   14                  5   14
>>>   6   15                  6   15
>>>   7   16                  7   16
>>>   8   17                  8   17
>>>   9    0                   9    0
>>>  10    1                10    1
>>>  11    2                11    2
>>>  12    3                12    3
>>>  13    4                13    4
>>>  14    5                14    5
>>>  15    6                15    6
>>>  16    7                16    7
>>>  17    8                17    8
>>> which is simply the initial ordering with a change in the order in which
>>> processors handle nodes.  Could it be that the partitioning is not unique
>>> and each time the algorithm only tries to obtain the "best" possible
>>> ordering depending on the initial distribution? If so, how should I know
>>> what ordering to start with?
>> Yes, ParMetis does not provide a unique "best" ordering, which is at least
>> NP-complete if not worse.
>>    Matt
>>> I am really confused and would appreciate if someone could provide some
>>> insights.
>>> Thanks,
>>> Mohammad
>> experiments lead.
>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110729/21dfcde3/attachment.htm>
