[petsc-users] memory corruption
Hong Zhang hzhang at mcs.anl.gov
Thu Jul 28 15:05:24 CDT 2011
Rebecca:
Turn off orderings and some options, e.g.,
-mat_superlu_dist_equil NO -mat_superlu_dist_rowperm NATURAL
-mat_superlu_dist_colperm NATURAL
Do you still get memory corruption?
Hong
> Hello all,
> I tried to use superlu as a direct solver running on Hopper, but found that there are some memory corruption errors:
> x/xyuan> cd $PBS_O_WORKDIR
> Directory: /global/homes/x/xyuan/Workspace_Nersc/cartmhdpdslin/trunk/test_superlu_as_direct_solver/m256_p1024
> test_superlu_as_direct_solver/m256_p1024> aprun -n 1024 ./twcartffxmhd.exe -options_file option_twcartffxmhd_256
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25137 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25146 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25144 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25133 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25136 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25142 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25145 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25148 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25149 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25147 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25135 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25134 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25138 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25141 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25140 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25139 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25132 : Permission denied
> [0] ERROR - MPIU_nem_gni_get_hugepages(): Can't create file /var/lib/hugetlbfs/global/pagesize-2097152/hugepagefile.MPICH.1.25143 : Permission denied
> cartesian coordinate code(np = 1024)
> start time = 0.0000
> time accuracy order = 2
> viscosity = 0.0500
> resistivity = 0.0050
> skin depth = 1.0000
> hyper resistivity = 0.00000630
> hyper viscosity = 0.00503929
> problem size: 256 by 256
> dt = 0.1000
> ******* start solving for time = 0.10000 at time step = 1******
>  0 SNES Function norm 6.220836330249e-03
> Linear solve converged due to CONVERGED_ITS iterations 1
>  1 SNES Function norm 3.041982522542e-07
> *** glibc detected *** *** glibc detected *** *** glibc detected *** *** glibc detected *** ./twcartffxmhd.exe: *** glibc detected *** *** glibc detected *** *** glibc detected *** *** glibc detected *** *** glibc detected *** ./twcartffxmhd.exe: *** glibc detected *** *** glibc detected *** *** glibc detected *** *** glibc detected *** *** glibc detected *** ./twcartffxmhd.exe*** glibc detected *** *** glibc detected *** *** glibc detected *** ./twcartffxmhd.exe: malloc(): memory corruption: 0x0000000001e31280 ***
> Any idea what is wrong here?
> Thanks very much!
> Xuefei (Rebecca) Yuan
> Postdoctoral Fellow
> Lawrence Berkeley National Laboratory
> Tel: 1-510-486-7031
