[petsc-users] Question on re-coding ex29
Alan Wei zhenglun.wei at gmail.com
Wed Jul 27 14:46:25 CDT 2011
Dear John,
    Thanks for your quick reply. I think the error message says that the
BCType has some problem. However, it is originally there and I have not
changed it at all. Is that because I define it in ComputeRHS again and let
ex29.c include ComputeRHS.h so the BCtype is duplicated?
thanks,
Alan
On Wed, Jul 27, 2011 at 2:04 PM, John Chludzinski <jchludzinski at gmail.com>wrote:
> Without wading through the attached zip file, it looks like you're missing
> some typedef's that come from a missing include file.  ---John
> On Wed, Jul 27, 2011 at 2:38 PM, Alan Wei <zhenglun.wei at gmail.com> wrote:
>> Dear Sir/Madam,
>>     I hope you're having a nice day.
>>     I asked several questions about src/ksp/ksp/example/tutorial/ex29.c
>> before, and learned some beginning staff of PETSc. Right now, I want to
>> start to use it to my own program. Firstly, I want to isolate the ComputeRHS
>> function in ex29, which means I want to put ComputeRHS to another c program
>> file. I did that; however, some problem pop up when I compile it.
>> /home/zlwei/soft/mercurial/petsc-dev/arch-linux2-c-debug/bin/mpicc -o
>> ex29.o -c -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
>> -g3 -I/home/zlwei/soft/mercurial/petsc-dev/include
>> -I/home/zlwei/soft/mercurial/petsc-dev/arch-linux2-c-debug/include
>> -I/home/zlwei/soft/mercurial/petsc-dev/src/dm/mesh/sieve
>> -D__INSDIR__=src/ksp/ksp/examples/tutorials/ ex29.c
>> ex29.c: In function ComputeRHS:
>> ex29.c:39: error: storage class specified for parameter BCType
>> ex29.c:44: error: expected specifier-qualifier-list before BCType
>> ex29.c:61: error: expected =, ,, ;, asm or __attribute__ before { token
>> ex29.c:117: error: expected =, ,, ;, asm or __attribute__ before { token
>> ex29.c:130: error: expected =, ,, ;, asm or __attribute__ before { token
>> ex29.c:197: error: expected =, ,, ;, asm or __attribute__ before { token
>> ex29.c:220: error: old-style parameter declarations in prototyped function
>> definition
>> ex29.c:220: error: expected { at end of input
>> make: [ex29.o] Error 1 (ignored)
>> ComputeRHS.o -c -Wall -Wwrite-strings -Wno-strict-aliasing
>> -Wno-unknown-pragmas -g3 -I/home/zlwei/soft/mercurial/petsc-dev/include
>> -D__INSDIR__=src/ksp/ksp/examples/tutorials/ ComputeRHS.c
>> /home/zlwei/soft/mercurial/petsc-dev/arch-linux2-c-debug/bin/mpicc -Wall
>> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3  -o ex29
>> ex29.o ComputeRHS.o
>> -L/home/zlwei/soft/mercurial/petsc-dev/arch-linux2-c-debug/lib  -lpetsc
>> -Wl,-rpath,/home/zlwei/soft/mercurial/petsc-dev/arch-linux2-c-debug/lib
>> -lflapack -lfblas -lm -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -ldl -lmpich
>> -lopa -lmpl -lrt -lpthread -lgcc_s -lmpichf90 -lgfortran -lm -lm -ldl
>> -lmpich -lopa -lmpl -lrt -lpthread -lgcc_s -ldl
>> gcc: ex29.o: No such file or directory
>> make: [ex29] Error 1 (ignored)
>> The program and modified makefile are attached. Could you please take a
>> look and give me some suggestions.
>> best,
>> Alan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110727/aaff44cf/attachment-0001.htm>
