[petsc-users] PETSc, C++ and Eclipse
Mohammad Mirzadeh
mirzadeh at gmail.com
Wed Jul 27 13:18:45 CDT 2011
Ok then. Now I don't have enough experience with Eclipse so
I apologize beforehand if you already know these/have tried them out. If
not, hopefully they can be of help. I assume there should be a way in
Eclipse to give it the link lib directory. In plain makefile that's just a
simple step when linking. To get all the needed linklibs for petsc, you can
do
make getlinklibs
in the $PETSC_DIR. As for the needed include files, they are all located in
$PETSC_DIR/$PETSC_ARCH/include
Again, its easy to use these directories along with your makefile. I'm not
sure about how you give them to Eclipse though. Hopefully this has been
helpful.
Best,
Mohammad
On Wed, Jul 27, 2011 at 10:52 AM, Matt Bockman <mdbockma at ucsd.edu> wrote:
> Just pointing it to the library would be sufficient.
> Matt
> On Wed, Jul 27, 2011 at 10:21 AM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>> So do you want to be able to compile PETSc with Eclipse or just point it
>> to the library to use in your own applications?
>> On Wed, Jul 27, 2011 at 9:14 AM, Matt Bockman <mdbockma at ucsd.edu> wrote:
>>> Thanks Mohammad,
>>> I'll give that a shot. I use Qt Creator for some GUI applications so I am
>>> familiar with it, but I've never tried doing a non-Qt project in it. I'd
>>> really like to get Eclipse to work.
>>> Regarding the makefiles for eclipse. There are makefiles that it
>>> generates (which are for GNU make) but I think I can also manually create my
>>> makefiles. After sleeping on it, it seems like this might be the best
>>> option, unless I can figure out a way to configure eclipse to include the
>>> conf/variables and conf/rules files in the makefile.
>>> Matt
>>> On Wed, Jul 27, 2011 at 12:01 AM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>>>> Although this is sort of orthogonal to what you do right now,
>>>> I recommend Qt Creator as an alternative IDE to Eclipse. It links nicely
>>>> with PETSc(or any other library for that matter) and has excellent c/c++
>>>> support.
>>>> Mohammad
>>>> On Tue, Jul 26, 2011 at 7:22 PM, Barry Smith <bsmith at mcs.anl.gov>wrote:
>>>>> There is a tiny bit of information in the PETSc users manual about
>>>>> Eclipse:
>>>>> \section{Eclipse Users} \sindex{eclipse}
>>>>> If you are interested in developing code that uses PETSc from Eclipse
>>>>> or developing PETSc in Eclipse and have knowledge of how to do indexing and
>>>>> build libraries in Eclipse please contact us at \
>>>>> trl{petsc-dev at mcs.anl.gov}.
>>>>> To make PETSc an Eclipse package
>>>>> \begin{itemize}
>>>>> \item Install the Mecurial plugin for Eclipse and then import the PETSc
>>>>> repository to Eclipse.
>>>>> \item elected New->Convert to C/C++ project and selected shared
>>>>> library. After this point you can perform searchs in the code.
>>>>> \end{itemize}
>>>>> A PETSc user has provided the following steps to build an Eclipse
>>>>> index for PETSc that can be used with their own code without compiling PETSc
>>>>> source into their project.
>>>>> \begin{itemize}
>>>>> \item In the user project source directory, create a symlink to the
>>>>> petsc/src directory.
>>>>> \item Refresh the project explorer in Eclipse, so the new symlink is
>>>>> followed.
>>>>> \item Right-click on the project in the project explorer, and choose
>>>>> "Index -> Rebuild". The index should now be build.
>>>>> \item Right-click on the PETSc symlink in the project explorer, and
>>>>> choose "Exclude from build..." to make sure Eclipse does not try to compile
>>>>> PETSc with the project.
>>>>> \end{itemize}
>>>>> We'd love to have someone figure out how to do it right and include
>>>>> that information.
>>>>> Barry
>>>>> On Jul 26, 2011, at 4:32 PM, Matt Bockman wrote:
>>>>> > Has anyone gotten PETSc to work w/Eclipse? Eclipse nicely generates
>>>>> all my makefiles for me for my current project (which is written in C++).
>>>>> I'd like to link PETSc w/my application but I'm not sure how to do this.
>>>>> > Suggestions?
>>>>> > Thanks,
>>>>> > Matt
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110727/41d57cce/attachment.htm>
